Please help won't start
Old Apr 24, 2009 | 06:50 PM
guntee1's Avatar
Changed knock sensor wire 91 3vze now it won't start everythings plugged in have spark, plugs are getting wet fuel pumps pumpin rolls ten times fires quits thats all i can get out of it any help appreciated
Old Apr 24, 2009 | 07:27 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Have you tried resetting the ECU?
Old Apr 24, 2009 | 08:01 PM
Sin91's Avatar
abecedarian asked me to ask you if the intake pipes are all hooked up and the distributor is set properly and is not out 180 degrees or something.
Old Apr 25, 2009 | 05:33 AM
TNRabbit's Avatar
Do you have the VAFM connected?
Old Apr 25, 2009 | 06:36 AM
nv4runner's Avatar
Really wet plugs can keep your rig from starting. There is a fuel return line that is mixed in with all those vacuum lines on the passenger side. Make sure that your lines are hooked up properly.
Old Apr 25, 2009 | 07:44 AM
thook's Avatar
Sin is now channeling Abe. Cool!!!! You should start holding seminars and publishing Yota-self help manuals.
Old Apr 26, 2009 | 08:00 AM
guntee1's Avatar
checked all lines and hoses? checked timing what else could it be?
Old Apr 26, 2009 | 08:36 AM
sb5walker's Avatar
Can you manage to wrestle any codes out of the beast?
Old Apr 26, 2009 | 11:31 AM
guntee1's Avatar
no codes yet do you have to have the alt belt and rad in to run or should it run without that stuff.
Old Apr 26, 2009 | 03:34 PM
mattaway's Avatar
you can run it that way in the driveway for a little bit, but i wouldn't drive it like that.
Old Apr 27, 2009 | 03:58 PM
guntee1's Avatar
Changed intake and messed with timing finally got it with no engine codes wa ho! thanks everybody!
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
