Changed knock wire won't run!
Old Apr 23, 2009 | 07:31 PM
guntee1's Avatar
Please help me boys Changed knock sensor wire in my 91 truck 3zve and now it won't run it rolls about ten times fires and quits within seconds. Checked fuel pump, wires, conections three nights of insanity before i remembered this site wich helped me with my engine change last year thank you for that! so any help would be appreciated
Old Apr 23, 2009 | 07:45 PM
toyota4x4907's Avatar
any CEL codes?
Old Apr 23, 2009 | 07:52 PM
Kiroshu's Avatar
did you put it back together right.... sounds like maybe when you did that you may have forgotten or messed up the intake manifold gaskets..... if they are leaking it does this.... all lines hooked up.... wires in right places.....? Check engine light? If so get codes....
Old Apr 23, 2009 | 11:46 PM
TNRabbit's Avatar
You DO have the VAFM back in place & plugged in, RIGHT?
Old Apr 24, 2009 | 03:06 PM
scope103's Avatar
Losing the knock sensor will throw a code, but I don't think it will prevent you from starting.
As TNRabbit hints: you need to take a deep breath and think systematically. Fuel, air, spark: what are you missing?
Old Apr 24, 2009 | 06:55 PM
guntee1's Avatar
what is the VAFM and where is it located? Gaskets should be good only go on one way?
Old Apr 24, 2009 | 06:57 PM
guntee1's Avatar
can you get codes if it has not ran for more than a few seconds?
Old Apr 24, 2009 | 07:06 PM
RMA's Avatar
RMA
Can you take some pictures of the engine compartment and post them here.
Maybe 3 or 4 from diffrent angles.
Maybe we might be able to see something wrong, just maybe.
Old Apr 26, 2009 | 08:02 AM
guntee1's Avatar
get back to you
Old Apr 26, 2009 | 02:48 PM
guntee1's Avatar
still trying go again tomorow
Old Apr 27, 2009 | 04:00 PM
guntee1's Avatar
Changed intake and messed with timing finally got it with no engine codes wa ho! thanks everybody!
JF9243176
Oct 8, 2017 04:21 AM
serenity03k64
Jun 27, 2015 07:59 AM
newzingo
Jun 24, 2015 01:50 PM
JF9243176
Jun 24, 2015 04:53 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
