87-88 4runner as a daily driver?
Old Apr 27, 2009 | 10:48 AM
ARK_SWAMP_RIDER's Avatar
I was just curious as to how well one of these would hold up as a daily driver. I'm looking for a cheap vehicle, and I've found several of these in good shape with ~200k miles (22re 5 speed) for $2k-$3k. I really wanted something newer (96+), but don't wanna spend that much money. I know for the most part these things are rock solid as far as the motor/tranny. However, I'm worried that with a 20+ year old vehicle that I'll have a lot of small problems here and there. I'll probably be driving it ~10k miles a year. Are these more/less reliable than the 96+ with a 3.4 (and similar miles)? I can afford the vehicle, but I won't be able to afford a lot of maintenance (will do stuff like fluid changes, just not stuff like the rear end going out and the like). I've got a 87 and really like it with the removable top, but it's strictly a farm vehicle, might see the road 10 times a year. I've never drove it daily, so not sure how adding the miles will effect it. Thanks for any help, it's greatly appreciated!
Old Apr 27, 2009 | 10:55 AM
malteserunner's Avatar
I DD my 87 with no problems. If you are looking for something a little more road friendly, I'd buy a 3rd gen 4Runner. My buddy just got his 99 for $4k with 150,... miles. People are hurting for money out there; it's a great buyers' market. Just my $0.02.
Old Apr 27, 2009 | 11:00 AM
Windsor's Avatar
My '87 is my DD, when I'm not riding the VFR (hence the "mall crawler" tag).
Old Apr 27, 2009 | 11:12 AM
BigBluePile's Avatar
I drove my '86 4Runner religiously for years 40-50 mile commute daily, 5 days a week, 70 mph on 33's/35's. Made for lots of oil changes. I've also done two coast to coast cross country trips and I drive it like a sports car. So yeah, I think you'll be ok. Just keep it simple and it'll run just fine and start every morning and be RELIABLE.
If you find a vehicle that's been "basically" taken care of and that's not completely factory still and had routine maintenace done, then go for that.
Old Apr 27, 2009 | 11:17 AM
I'll be doing very little off roading, I just want something I can drive daily and then hunt/fish out of on the weekends. I've got a Mustang I'll be driving on the nicer days, so the 4runner won't be my only rig. I'd like the 96+, but I really only have $2k to spend (the whole point at issue is a cheap but reliable dd). Thanks for the opinions!
Old Apr 27, 2009 | 11:27 AM
Junkers88's Avatar
Although I'm a little out of your year range I bought my 89 for 1500$ and have been driving it every day since I figured out what the starting problem was (ground cable from the battery loose at the engine ). I've actually put very little money into it since I had a bunch of the off-road parts already on another vehicle. Find one that's been taken care of at least a little and you'll do fine. I DD mine to work 5 days a week and one weekend a month as well as wheeling the other three weekends and sometimes after work when I get a chance. I'll be using it for camping/fishing/hunting etc this year and have no worries about driving it anywhere.
Old Apr 27, 2009 | 11:33 AM
Cwaters1184's Avatar
i bought mine with the intention of DD'ing it... its getting there but its still gonna need some green to make it reliable. but i bought mine as a work in progress.
Old Apr 27, 2009 | 11:57 AM
4banginRunner's Avatar
I DD my 87, and weekend wheel with no problems, and I've gotten 25mpg with it, usually around 19-22 depending on how I drive
198K, 22RE, 5spd swapped...only mechanical thing that went wrong was the water pump, but that was OE so was to be expected.
Old Apr 27, 2009 | 01:30 PM
Junkers88's Avatar
The water pump went out at only 198,000 miles? Oh that is just crap!!!!
Old Apr 27, 2009 | 01:57 PM
I know..I was expecting to see terrible problems like this start at 300K
Old Apr 27, 2009 | 02:03 PM
Junkers88's Avatar
Yeah I'm with you. At 198,000 I can see a belt getting a little worn or maybe needing an oil change but the water pump should last at least 300,000.
Old Apr 27, 2009 | 02:05 PM
bxlt's Avatar
I DD mine 30 miles a day, I used to have a 200 mile commute and would drive my 86 with 250k (when I bought it) 3 days a week for a couple of months with no problems (stopped doing the 3 days when I bought a car that got 30mpg just to save on gas)
So far in the 2 years I have owned it and the almost 30,000 miles I have put on it all I have spent was $1500, to buy it, $600 new tires, and $600 for clutch and tranny, and about $200 for tune-up/repairs I think its pretty good for a truck with that many miles. Just know with that many miles there may be a few big ticket items that spring up every now and again but generally they run and run good all day long!
Old Apr 27, 2009 | 02:16 PM
tj884Rdlx's Avatar
well, man you know it depends on what you buy. i bought an 88 with over 200k as a DD and to build into a reliable camping rig. MY concern at the time was the body: no rust, no bondo, no frame work. interior was all there too.
first week, the radiator started leaking. i put that in. second week, i had to replace the clutch hydraulics. few weeks later, HG failed from first rebuild, so i had 2nd rebuild done. few weeks later, to address crappy shifting issue, i had a clutch done, and changed all the drivetrain fluids. months go by, and nothing major, so i spring for 33"s, and now i have to regear and get some lift for clearance.
i also need new rear springs/shackles to address a death shake at 60mph. and i add a half quart of oil every 3 wks.
but i've driven to work every day, and i've taken some 8hr trips in it too. i love the thing and i'll drive it 'til they make driving illegal.
GET YOU ONE!
Old Apr 27, 2009 | 03:53 PM
Sin91's Avatar
abe drives his 88 truck to and from work sometimes up to 1500 miles each way and has done that for a few years and doesn't have a problem. he's got like 240000 miles on the truck and he doesn't think twice about going. he just carries some extra oil and goes.
he has a 88 4runner and checks his fluids at least every other stop for gas.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
crashburnoveride
Jul 10, 2015 06:39 AM
coryc85
Jul 6, 2015 04:07 AM
