Jumpy temp guage... beats me.
Old Apr 22, 2009 | 04:37 PM
Squeebs's Avatar
92 3.0 stick
The temp guage works fine if the truck isnt moving, or im not pushing the throttle...
If I'm giving it gas, the guage just stops working all together... If I'm coasting, its fine until i hit even the tiniest bump.
Cant figure it out to save my life...
Help.
Old Apr 22, 2009 | 04:39 PM
iamsuperbleeder's Avatar
ummmm, I'll be the first to suggest air pocket in the coolant system; any other takers?
Old Apr 22, 2009 | 04:41 PM
dntsdad's Avatar
Hmmmm.... radio and everything stays on fine if you give it throttle. If not, could be regulator going/out cause overvoltage problem.
If all that is fine....lose wire/ground. I would guess in engine compartment since torquing motor causes it to go out.
Old Apr 22, 2009 | 04:42 PM
dntsdad's Avatar
Didnt know that would cause his condition. Maybe I will learn something!!!
Old Apr 22, 2009 | 04:45 PM
you'd be surprised; I've seen strange things cause wierd gauge readings; like old rad outlet hoses that colapse with higher RPMs
but the torque theory sounds very possible too; check the wire running to the temp sensor and make sure it's in good shape, and that the wire itself is secured good on the sensor
Old Apr 22, 2009 | 04:48 PM
Squeebs's Avatar
I'll check that right meow....
Since im an idiot and dont wanna thumb through my chiltons, where is that sensor at?
Old Apr 22, 2009 | 06:00 PM
damn on the 3.0, I dunno... sorry...
I'm a 2nd gen 22re guy
Old Apr 22, 2009 | 06:13 PM
sb5walker's Avatar
It's the smallest sensor on the coolant block - that aluminum appendage on top of the motor in the back - just in front of the firewall and half under the plenum. On the older motors, the sender's position on the coolant block is in the front left; on the late models, it's just to the left of the largest attached hose.
Looks like this:
BTW if you need to order one, it's called the water (or coolant) temperature sender as opposed to the ECT - (engine coolant temperature sensor).
Fortunately all the sensors on that coolant block look different; unfortunately the plenum is partly in the way.
Old Apr 22, 2009 | 06:18 PM
pntbol11's Avatar
My vote goes to the faulty sensor. Probably a connection.
Old Apr 22, 2009 | 06:31 PM
Squeebs's Avatar
I tried bleeders air pocket theory... burped the system.
same problem.... sooooooooo i guess its that sensor or a bad ground.
BACK TO THE TRUCKMOBILE!!!!
Old Apr 22, 2009 | 06:38 PM
Squeebs's Avatar
Alright, so this thing is on the drivers side of the block in front of the fire wall and the intake assembly kind of blocks the view of it?
Not seeing it... i'll go look again i guess
Old Apr 22, 2009 | 06:59 PM
sb5walker's Avatar
No, the coolant block is in the center of the motor, on top, in the back. It has like 5 sensors or so and a couple hose attachments. The sender's location on that little coolant block is just to the left (looking forward) of the largest hose.
Old Apr 23, 2009 | 06:27 AM
Squeebs's Avatar
I knew that. I was just uh... testing you all.
Old Apr 23, 2009 | 06:41 AM
mt_goat's Avatar
Here's a pic of my old 3.0 (with auto):
MadMax48
Mar 3, 2020 10:33 AM
coryc85
Dec 5, 2015 08:42 AM
--Oz--
Sep 6, 2015 01:06 AM
