- HELP! #2 Cylinder shows Low/No Compression
- Pull up to the scene with my ceiling missin'
- jumped timing chain poor running/damage?
- What is this thing?
- Air Gap on distributor 3vze
- Parasitic draw?
- rough idle after valve cover gasket change
- Transfer case weight?
- rear end clicks when throttle on or off
- truck won't start
- A good day... Auto to manual swap
- 7.5A Charge Fuse
- What doors can i use on my 88 pickup sr5?
- Half shaft ripped out.. again. Need spacers.
- Coolant Sensor Connector
- Engine won't turn over
- dim headlight & carburetor/emission issue
- "Click", like a switch and the valve tapping disappears...
- Just scored a 87 22re 5spd but what is this?
- New engine for only $895 installed? Cylinder 6 Misfiring
- What parts should I replace when I pull my injectors
- Headlights cause idle drop...
- Suspension and doors on my 90 4x4
- 95 4runner (help with hoses) 3vz-e
- Mysterious spout on bottom of radiator?
- Shifter problem
- Replacing bench seat, whats ur opinion on best looking buckets?
- not rear main seal
- toyota truck dash in '86 4runner?
- Need the Trick to remove intake on 3vze
- Where to start with a/c troubleshoot
- Reman 3vze Engine Swap - oil priming / oil in camshafts
- '89 sr5 torsion bar lowering?
- Zuk Mod but no bottom bumper guard
- 1986 parking brake cable pin
- 1987 pickup 4x4 troubles
- Battery/Alt problem
- Drivers window crapped out
- Spindle->Axle seal
- 22re Exhaust Suggestions??
- Steering-IFS to SOlid axle
- 7.5" and 8" carrier ?
- Looking for an 88 FSM
- changing to a 4.3 chevy
- 1990 3.0 code 25 troubleshooting
- Driver's side window comes off track and hard to roll up and down
- Vacuum issues? No 4wd
- Need thoughts on these injectors for 3vze
- rear drive shaft issue, self inflicted.
- 3vze strange noise
- What is this and what does it do?
- Arb high lift jack adapter
- Ode to Milky Oil
- 87 4runner 22re running rich!! PLEASE HELP!!!
- Exhaust fab help
- Anyone seen a forerunner in this condition after 25 years? Price seem ok?
- 1993 4runner back glass problems .....
- 89 4runner wipers
- Identify this sound and win a date with Kate Upton!
- COR/Circuit Open Relay Constant Clicking
- Steering wheel help
- Found Something Peculiar Under Valve Cover '89 22r
- 4runner kayline STC soft top help
- Awesome Hilux Part Diagram
- Leaking Removable Sunroof
- Can anyone post or link to a healthy sounding 22R/E?
- Compression results
- 93 4Runner has horrible acceleration/bogs down
- Which Fender Flares Should I Order For My 1995 Pickup
- where to purchase '93 PU tailgate part
- Anyone running BJS's on a 1st gen 4Runner with 3rd gen rims?
- 86 xcab SAS questions
- 88 3.0 starting issues
- Rear shock rusted out?
- Bed rail caps for 1986 pickup?
- V6 valve cover check list
- Oil Leaks
- NWOR headers
- Bad Head Unit?
- 1991 5vz 4runner speedometer swap
- 1986 parking brake pulley
- Loose Auto Shifter Fix
- Dead battery jump start not working
- 89 Toyota Pickup
- have an odd question
- Reg Cab Body on Extended cab chassis
- Truck is totalled. Now what?
- Speedometer cable wont connect to instrument cluster
- How many pedal pumps does it take to start your 22R?
- Valve clearance, thoughts please
- 4R noob; DCSB Tacoma owner; wanting an 87 Turbo!
- 87 header question.
- Radio/Power issue
- detent cable on a 4 speed overdrive 1987 toyota pickup
- Pickup and 4runner taillights interchangeable?
- Need help with 22r to v6 truck exhuast.
- Help me identify this part
- 93 toyota will not crank power issues.
- E-brake lever interchange?
- Mysterious connector behind front bumper...
- Where is this transmission plug? (pics)
- Slow 4runner when o/d is on
- 22r oil filters and the check valve/anti drainback valve...
- Ifs lift kit opinion
- A/C wire -- where is it?
- warm-up bogging..help!!!
- 94 3.0 runner running hot
- Back window help
- Sliding rear window slides hard
- 93 2wd Toyota not starting
- Why is this 22RE pushing exhaust like this?
- 95 4runner -dtc 71---HELP
- '90 toyota pickup, cant shift when stopped
- Hard on gas and loss of power
- no heat inside, well just alittle
- 89 yota pick up bull bar?
- Driveshaft and truck will not start!
- Best First Gen Parts Catalog?
- Front Main Seal Replacement 22RE (pics)
- Cylinder five = no detonation
- Body lift running rough (after install)
- 89 4runner rear power window issue
- headlight switch
- suspension question
- Washers on shackles
- Fuel Lines
- Pinging
- cam and crank seal drivers?
- Death Wobble on my Yota??
- 89 Rear end jumping of some sort
- 88 Toyota Pickup Leveling Kit?
- Climate control knob?
- Sway bar out?
- Xtra cab rear speakers
- Where to buy torque converter?
- Gear question
- Where does this wire go?!?
- #3 bypass re-route
- Let's talk about straight piping
- 93 22re running rough
- Hi from Oregon
- cv joints
- 1994 truck ready to BURN....help needed!!!!
- 88 Pickup radio/console wiring help
- Adding a tow hook from local parts store
- New Intake & Exhaust
- Heater hose - should I just make one?
- Parts selection for OME rear lift
- Loud squeal when accelerating
- master or slave cylinder?
- power and fuel problem 22re
- Sunroof air deflector clips
- 87 radiator cap question
- 87 yota 4x4 value mite sell
- Head light, Brights dont work? Please help
- 1990 2nd Gen 2DR engine shuts down @3,000 RPM.
- 1988 pick up, battery, start up, stalling and gauge issues
- Cleaning Massive Amounts of Rust out of Radiator
- hzj 75 landcruiser 2 inch body lift problems
- 93 22re conversion to 22ret
- hesitation. no power past 1/4 throttle when in gear
- Chopping Stock Top to Make a Soft Top
- Does taking off Catalytic converter burn out O2 sensor.
- Massive Oil Leak in front of engine
- Accurate Body Measurements
- 87 4runner spark plug issue
- 94 pickup exaust system
- 1988 runner cold start issue
- when i crank up my 92 22re the idle goes from high to low
- Fuel Injectors Rebuild Mine or Buy New or Reman??
- check out my 22re head.. something wrong yo!!!
- New member here!
- What in the world are these brackets for?
- Front End Shakes
- spring tensioner and hyrdaulic tensioner on 3vze?
- Off road lights
- Brake booster vacuum hose
- Radiator Mounts are gone...
- Fire coming out of valve cover...
- Engine rebuild or replacement for 1986 Toyota Truck... need advice please!
- Truck keeps dying out !
- How many glow plugs for 1994 3td?
- Flywheel to crankshaft alignment on 5 speed swap
- 4.70 t100 gears... will they work
- cheap extended shocks!
- Hazard problem PLEASE HELP Gen 2 4Runner
- Weird temporary power loss
- 22r vs 5vz which one would be better?
- 87 22RTE - Hard to Start
- Mounting center console
- Is anyone around here from Massachusetts
- Need to rebuild car. Also need to replace exhaust and muffler. Which one first?
- Fresh rebuild 22re, sounds fine, but has no power, what now?
- Glassworks unlimited: anybody purchased from them lately???
- 1986 Toyota truck front end problem...
- Look Whats new
- new guy here with a timming question
- Do I need head gasket repair? What's wrong?
- As I sit here in gear...yea jus sitting here.
- I got a FREE 95 Runner Limited 4wd
- 86 and 87 Rear Break Cylinder
- W56 Gear Oil
- 94 runner needs shocks. Any suggestions?
- Can someone I.D. this tranny? W56?
- 2nd Gen towing capacity
- 22re awful noise
- Turning radius and lock to lock question?
- Complete brake system refresh and now mushy pedal?
- Bypassed AC Cut Relay..
- Valve Stem Seals, Would you change them?
- Code 52 only when cold?
- i need a miracle
- What year of T-100 rear axles for long travel swap?
- Do I need an adapter for 2-1/4" exhaust?
- Fuel injector overhaul 3vze
- 22R Head Gasket with Extra Coolant Holes??
- Cold Compression Test?
- auto to manual swap
- Factory skid plate bolt size?
- rear wiper diagram 86 4runner
- Vibration after OMEmu Leaf Lift.....
- Losing hope!
- Log on yesterday and got this ?
- Leaky Cam plugs
- sr5 seat swap question
- Experts weigh in! Brainstorming ways to beef up IFS tie rods
- 1st Gen 4Runner: Swapping in later model OEM keyless entry?
- 87 4x4 p/u rear axle pressure help
- 88 3.0 Rebuild
- '91 scanner & check engine light
- Replacing my 22re gas tank, how to clean the fuel system too?
- Flipped my 1994 truck, now what?
- SAS Conversion Question
- Valve adjustment Wirte up?
- 1986 22re bucking, power cut out, checked TONS of things, please help
- truck won't start
- '02 coilovers on an 87??
- 81 22r into an 87 HELP!
- Diagnosis Help Please
- bad water leak please help
- Parasitic draw drains my batt.
- fan clutch question
- Chev swap into 4runner
- 22re White Smoke/check engine light
- Rear Coils Zuk Mod on Stock 1st Gen 4runner
- Suggestions needed on removal of retaining clip
- Need replacement aisin manual locking hub part.
- Tabs from front faceplate to hood
- Fluids
- Pcv valve?
