Sliding rear window slides hard
The sliding rear window on my '92 pickup slides very hard, the drivers side is so stuck I'm afraid I'm going to break the window, although i can slide it open. I tried apply grease to the tracks like other posts have suggested but to my surprise it has done nothing. I'm having trouble figuring out where it is binding up, is the rubber upper and lower tracks the only place it could be binding? Almost seems like the weatherstripping on the stationary window might be applying pressure to the slider. If anyone has successfully fixed the problem feel free to chime in, thanks!
Also, how easy should they slide open when working properly? Finger operation?
Use silicone lube not grease. Silicone will freshen up the material , but petroleum products will make them swell which makes the problem worse. Verfify there is a little bit of up and down play , the frame might be bent.
Jun 1, 2021 01:51 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
cyclist231
Jul 7, 2015 12:56 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
