Oil Leaks
Old Apr 2, 2013 | 09:55 AM
Nookster's Avatar
Oil Leaks
Hello everyone, newb here. I bought a 89 4runner a year or so ago and its been great. Runs great and doesn't burn oil but leaks oil like a sieve. Over the weekend I finally started working on these leak problems. Replaced the rear main seal and oil pan gasket, what a pita but I still have a little skin left on my knuckles. I think I still have another spot that may be leaking though. I was looking through the maintenance thread for a post that list all possible spots a 3.0 manual shift could leak from and didn't see anything specific. If someone knows could they please post it up. If I still have a small leak I think its coming from the front on the engine. But it doesn't look like the valve cover. Anyway any guidance will be appreciated.
Old Apr 2, 2013 | 10:23 AM
mopar_runner's Avatar
Oil leaks can be tricky. I had a leak I thought was coming from the rear of the engine since I could see drips from both sides of bell housing. Turns out I neglected to put thread tape on a plug in the oil pump (3vze). Oil would slowly creep down the lip of the oil pan to the back. Any place where there is a hose, gasket, or seal is a potential leak. Power wash it so you have a somewhat clean starting point and follow the drip backwards.
Old Apr 2, 2013 | 10:25 AM
BTW, welcome! Lots of very good info and people here to help!
Old Apr 2, 2013 | 02:38 PM
Co_94_PU's Avatar
Clean dry engine, flash light and inspection mirror. Keep at it and you'll find them all. Good luck!
Old Apr 2, 2013 | 03:00 PM
Nookster's Avatar
Thanks for the reply's. looks like it will be gunk and a power wash this weekend plus I finally broke down and ordered a service manual that will be in the mail by then.
Old Apr 2, 2013 | 04:04 PM
scope103's Avatar
Gunk (spray-on engine cleaner) and a garden hose may be enough. You've got to keep that power washer away from anything electrical. That said, it will certainly give you a clean engine!
Old Apr 2, 2013 | 04:22 PM
hockey88fan's Avatar
The oil cooler would be a good place to look, mine was leaking bad. I did away with the oil cooler when I had the motor rebuilt.
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
