89 Toyota Pickup
89 Toyota Pickup
Hi, I'm new to forums. I'm looking at buying an 89 Toyota Pickup for $2000. He says
"22re with a new head, a new cam, a new timing chain, new tie rod ends and new ball joints. It also has tires that were just bought around 5 or 6000 miles on them. The axles have 5.29 gears and theres an arb air locker in the rear. Two weeks after i did the motor work i wrecked it, so it needs front end parts but still has a clean title."
I don't know, is this a good deal?
Thank you for your input,
Cameron
Cameron
2wd or 4wd? How many miles on it? No matter what, it seems like a lot for a truck that's just been wrecked. Find out exactly what needs to be repaired on it. If you can't do the work yourself, you should definitely walk away.
BUY!!! Cant go wrong. These trucks are all getting harder to find in good shape. If its all about parts needing to be replaced then who cares. Least its straight. $2000 aint that much.
Another question, I have a 79 F150 with 33x12.5x15 tires, the 89 Yota has the same tires. I want to switch wheels. Do I need to get adapters with spacing, to eliminate the tires rubbing?
as for buying the truck - i think it really depends on how much damage was done when it was wrecked. as for clean title...i can go out and roll my truck and it will still have a clean title until an insurance company gets involved
on the plus side, if it truly has a fresh engine and ARB w/5.29s, new tires, etc - just in parts you're looking at well over $2k, so could be worth it...
6th Gear
19
Dec 10, 2019 07:31 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
