- '89 High Idle
- 22re to 22r 1987 4Runner
- New Engine!
- 22re starts then stops immediately despite effort
- Roll down rear window without power
- ADD - disable the automatic disconnect differential?
- How the heck to remove the lisence plate trim!?
- frequent clicks, no start
- AC compressor pulley R&R
- Hi!
- 1995 A/C Suction and Discharge Line Nightmare!
- Help with swap on 2nd gen
- Installed Clutch Manufacturer/Model
- Clutch Replacement Problem
- Need Rear Locker Acutator
- Attempting to control AC with haltech / 94 pickup
- Fuel pump hose issue
- ID this gasket
- Radiator Replqcement
- Recommrndations needed: Vendor for exhaust system
- '85 Dolphin Running Weak!!
- New Brake swap upgrade for 1983–1995 Toyota Pickup 2WD front wilwood, 12.2" rotors.
- Replacing the rocker tower screws 22re
- Crank NO start
- New guy, same old ideas....
- 4x4 indicator switch
- Asking for a friend 1991 V6 4wd question
- IAC Valve and Surging Idle
- Need help with ground wire locations and fire issue 3vze
- Clutch issue
- W56 Reverse Idle Gear, Now Available
- Duramax Delete Pipe Questions and Considerations
- Where Does This Part Go (4Runner)
- Efi relay burning up…
- Leaking Steering Box - I think
- Persistent Hub Squealing Noise Diagnosis
- New to forum: Weld in repair panels - 1991 Pickup 4x4?
- Searching for this decal
- Driver side oil cooler outlet help. Silicone Cap or replace with plug ?
- Dome light bulbs
- adjustment of brake pedal height and H tool
- 22RE Condenser Packing Foam?
- HELP!!! Need to replace coolant pipe in the valley
- Toyota 1991 Pickup Factory Repair Manual & Electrical Wiring Diagram
- Something blew up my ECU, culprit still unknown 1991 pickup 3VZE
- Shock legth question.
- Ebay listing https://www.ebay.com/itm/198251926778
- New to 4runners
- Help?!?
- 1988 $Runner - no power
- 1994 4runner Ls build
- Great supply house for 22RE parts
- W56b reverse gear
- Clutch line will not vacuum bleed - clogged???
- ISO part 61501-04020
- 1986 Pick Up Sending Unit 2 pin
- Grease fittings
- Timing Chain Guide Question
- Dash Cap Problem SOLVED
- 1986 2WD pickup
- Bimetal vacuum switching valve
- Air intake hoses
- 89 3.0 5speed help model
- 22RE Engine diagram
- 22RE to 5VZ
- Another turbo 22re build
- Retrofitting Factory AC
- High idle at cold start.
- Timing cover install 22re
- 1988 3VZE VAFM questions
- ITM 22RE heads on RockAuto - any good???
- OEM vs Silicone coolant hose kits?
- How to attach gas tank on long bed 4x4?
- Misfire
- Replacing Supra LSD with Lunchbox and Open Carrier
- Cranks on first start, when cold or hot, but after sitting 30 min
- 1988 3VZE 4runner long crank when outside temps are low
- 4WD doesn't engage unless I swap connectots on vacuum solenoids
- Rear window and center console button light bulbs
- Code 24 and 32
- in search of shifter knob - 1987 SR5
- Front axle bushings
- 22re misfire idle up to 2500 rpm
- Electrical help
- Repairing and Upgrading - 92 Pickup DLX
- 22Re valve springs
- Starting issue.. 1992 pickup 3vze, auto.
- Mystery Shifting Problem
- 5vz swap transmission question
- 22re cold start idle is low until I press on the gas
- 1987 R22 Carburetor parts
- chevy traverse rear disc swap
- Coolant leak at rear of engine (22RE)
- Replacement exhaust for '87 with 22RE
- Will '90-'95 4Runner Heater Core Box Fit Pickup?
- Tailgate Latch question
- Weird
- 92 3VZE - another Code 14 diagnosis
- SR5 Cluster Swap
- 3.0 loss of power under load (Randomly)
- I rewired my climate control on my '95 4runner
- 92 Yota Help
- W55 Whine, Rebuild Time?
- 91 wiring diagram
- Rocker assembly not flush
- Uggh.Engine knock after complete rebuild. Thoughts?
- What are these parts?
- Blower Motor Troubleshooting
- Help with sensor connectors on 88 3vze
- Code 42 VSS
- Where is the Oil Pressure Gauge Wire?
- 1994
- B-Pillar Trim
- Bell Ringing sound
- Steering wheel swap: 2nd gen to 1st gen
- No start after an alignment? Fuel issue.
- 1986 Toyota REC Wiring Help
- Trouble shooting
- 1985 Toyota Pickup 2WD Reproduction Bumper End Cap
- wrong main bearings
- Rear differential looseness/slop 92 pickup
- Old Man Emu Lift - Rear Springs Opinions and Experiences (Sorry to beat a dead horse)
- 89 4x4 pick up 22RE motor starts up then dies after 1 second
- 1995 4runner trouble-shooting
- Engine stalling
- Mystery coolant leak
- Does this 22RE sound normal..
- Quick tire question
- 1994 Toy pickup 4x4 Fuel pump access from bed
- Fluttering Timing Mark
- '89 pickup 4x4 extended cab
- What should the voltage from the alternator be?
- 1987 Pickup A/C Switch Bulb
- front lights
- Cooling Issue
- 1992 Toyota Pickup crank no start after attempted ignition swap
- 1987 pickup
- 1989 Toyota pickup taillight wiring
- Running lights and dash illumination not working
- Engine RPM drops when hitting brakes. New Brake System Installed
- 1988 Toyota Pickup Air Flow Meter
- 3D printing an Adapter for an SR5 Center Console Conversion Conversion
- Labeled Diagram needed
- Power mirror motors
- 1988 Pickup: CEL with VSS code (4.2)
- AC Low Pressure Side Pulls Vacuum with Compressor
- How to tell when the flywheel gear is bad?
- 1988 22RE: Only firing on 2 cylinders?
- 3.0L Engine starts great - then dies
- What is this white screw?
- CV boot and wheel bearing repack
- 1993 22RE 4x4 CODE 25
- Fuel Smell and Fuel Tank Vacuum
- Need Skid plate bolts 92 toy pu
- Coolant Leak (Water Outlet I believe)
- Fluid Types/Capacities?
- 22RE Ignition unit problem
- 1988 Toyota pickup 22re jerking at 70 mph
- Fuel Filter alternative
- 1988 22RE Throttle Position Sensor Behavior?
- 22RE Won't Idle.
- Weatherstripping for windows
- 1986 22re intake manifold question
- 94 4 runner issue engine
- Does a used ECU need reprogramming for an OBD1 truck?
- Where does this hose go?
- Help me figure out my 22re misfire
- Engine cuts out while driving for a split second
- Coolant Drain and Fill
- Need help finding a short coming from alternator red IG wire
- 94 toyota pick up v6 3.0 vze
- lights on dash
- 3VZE and ARP studs, valve job
- Noise coming from rear differential when coasting. Disappears when under load
- Temp gauge thread size
- 22RE Air Flow Meter Diagnostics?
- A-Pillar gauge pod needed
- 3vze Loud Knock on Cold Start
- 1988 4Runner harness connectors identification
- 1993 Pickup M/T 4WD High Compression
- Overheating mystery
- Fron passenger window stopped working
- Heat Inside cabin summer time
- 22RE high idle
- Charging System....Voltage Jumping Around?
- Axle Noise_IFS
- Heat at the legs part
- Truck ran fine until I "fixed" it!! Slight backfire upon deceleration...
- 1994 22RE AC compressor confusion
- Possible stuck cold start injector?
- 3.0 3vze Recall
- 87 4Runner 22re 5.29s and 35s. Real weak in 1st gear 2hi
- Heater/AC air filter?
- What goes there?
- No crank no start
- Replacing Cab Bushings
- Another “lifted truck shocks” question
- toyota hilux 1992 22re oil pressure spike after head gasked change.
- 1994 22re Freeze Plug Leak?
- 1994 Pickup: Failing Fan Switch(s)
- Different consoles, shifter bezel, trim, etc.
- Front Bumper 1990 Toyota Hilux
- Speedometer Sensor 93 SR5 4x4
- Rear heater hose routing
- Body harness wiring diagrams?
- Need 2 small parts - gas filler door locking tab & cig lighter knob
- Sometimes Hard to Start
- Generation Clarity
- Location of AC relay
- 1989 P/U 3.0 idle and driveability issues-Tons of work after sitting for years
- 88 4x4 frame
- Throttle position sensor problems
- '87 Under hood fuse box help
- How many miles on an Engnbldr timing chain kit?
- Need help sourcing connector terminals
- 1986 4x4 Motor mount issue? with pics!
- Parking brake adjustment/repair 86 Toyota 2WD
- timing chain or something else throwing off timing?
- Iso 1992 4 runner seat covers
- 22RE - Haltech Standalone EFI...Anyone?
- Dash Light Circuit on a 1986 4Runner DLX
- brake booster / hard pedal
- Differences between 3vz and 5vz?
- My head hurts...
- Rear chrome bumper endcaps (black plastic) needed
- Front End Steering/Suspension Parts....What Brand?
- I’m an idiot. Dropped razor into engine
- 1994 Toyota Pickup 4x4 Axle Question
- !988 22RE Toyota 4x4 Thermo Time Switch
- What’s up with my saggy rear? 1994 2wd manual pickup
- Front Diff Removal
- Fuel filter causing misfire?
- 90-95 front fender liners
- EGR mount to head - stud or bolt?
- 92 truck runs perfect then instantly switches to barley running
- Mechanic in Sacramento, CA
- Missing power mirror switch component?
- AC Magnet Clutch Bearing info
- What to change during engine swap
- DIY 3vze CAM Sprocket/PulLy holder Timing removal
- TQ specs for IFS Brake Job
- 87 4Runner - Rear Hard Brake Line - Thread Size?
- Looking for manual 4x4 transmission for 22re 4runner
- 3VZ-E Help
- 88 Toyota pickup 2wd auto swap options
- Low idle
