Heat at the legs part
Old Sep 1, 2025 | 11:37 AM
3vz92's Avatar
Helloo
I have an issue while driving my truck, i feel heat ( air heat) at the legs part. Someone told me that the cause for this might be solved if my install a valve at the heating hose and close it during summer season. Below is a picture of the heating valve . Please anyone could advise on this issue
Old Sep 1, 2025 | 02:37 PM
Robert m's Avatar
You're truck already has a valve there from the factory. Make sure it's opening and closing with the lever on the dash.
If you're feeling air movement from the ducting, you most likely have a bad seal on the fresh air flapper door. That is located behind the glove box in the dash. The seal is just foam and it degrades and falls apart with age.
cheez
Dec 1, 2019 08:03 PM
jordanhere123
Jan 14, 2015 11:23 AM
Gshock
Feb 23, 2012 08:26 PM
trudydog
Jan 24, 2012 11:43 AM
