Heat blowing cool air
Old Jan 22, 2012 | 01:05 PM
trudydog's Avatar
Hello all,
96 4 runner 357k miles and still running strong!
Heat is beginning to blow cold now. Blend door works fine, heat valve replaced last year, thermostat replaced this past summer.
Any thoughts before I take the thermostat out and test?
I read a post earlier regarding a vacuum line sharing the heat valve in the Engine compartment but that was for a 95. My valve is solely connected to the cable (the other end controlled by the heat select knob in dash)
tks in advance
Old Jan 22, 2012 | 01:08 PM
justin_4runner's Avatar
mine was just doing this and ended up beling low on coolent,
Old Jan 22, 2012 | 01:13 PM
trudydog's Avatar
coolant
I noticed it to be a little low but I blew it off as "no way it could be that".. wife just sped off to work but will top off in AM and report back...... Hopefully this is the simple fix.. thanks man!
Old Jan 23, 2012 | 01:34 AM
wyoming9's Avatar
Smile
Yes if the coolant is low no heat!!
Old Jan 23, 2012 | 05:48 AM
Jory121's Avatar
yup low on coolant....normally everytime, just top it off and check for leaks
Old Jan 23, 2012 | 03:58 PM
trudydog's Avatar
Thumbs up yep
well hell if you all weren't correct..... simple indeed, topped off and the heat happened. amazing stuff... still learning after 357,000 miles
thanks all. so simple sometimes the simple things just get overlooked;-)
Old Jan 24, 2012 | 11:43 AM
jimig's Avatar
I woulda started with taking your dash apart and replacing your heater core first. Glad it was a simple solution for you.
MO transplant
Apr 23, 2023 11:58 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mussy01
Dec 13, 2016 08:20 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
