clunk in reverse
Old Jan 22, 2012 | 09:55 PM
Lena's Avatar
clunk in reverse
so today i was backin out of my driveway to discovery that when i hit my bakes while going on reverse my truck started makin a gawdawfull clunkin and bangin sound, and suggestions of what i should check to see what it is?
lena
Old Jan 22, 2012 | 11:07 PM
stockwell45's Avatar
Is it one loud click noise or is it a continuous noise? Mine makes a loud click in reverse when I hit my brakes, and it seems to happen to others too with an auto tranny.
Maybe this will help
https://www.yotatech.com/forums/f2/s...everse-233787/
Old Jan 23, 2012 | 02:09 AM
Lena's Avatar
no its not one click, more like multiple clunks that shake the whole truck
Old Jan 23, 2012 | 07:25 AM
whitetoy's Avatar
Have someone crawl under there and look for something obvious.
Where is the clunking appear to coming from? The rear?
If so, maybe a broken spring leaf, loose shock, loose u-bolts, loose spare tire.
Maybe drive-shaft contacting gas-tank skid plate (happened to me once).
Old Jan 23, 2012 | 07:42 PM
Lena's Avatar
im gonna crawl under and look tommorow, il let ya know, im thinkin maybe its my brake caliper
Old Jan 24, 2012 | 11:40 AM
jimig's Avatar
I would also just look at your universal joints also. Make sure they aren't busted apart anywhere. Start with the visible easy stuff first before you start opening or removing things.
Old Jan 24, 2012 | 12:58 PM
DeathCougar's Avatar
If the problem is in the rear, it can't be a brake caliper since its drum brakes in the rear....
Old Jan 24, 2012 | 08:15 PM
Lena's Avatar
yeah i know dc, the clunking doesnt come from the rear, it just does it when im in reverse, regardless i know i need a new brake caliper because the threading where one of the bolts goes in on it is stripped, so everytime i hit the brakes the thing is movin
Old Jan 24, 2012 | 08:21 PM
87Toy22r's Avatar
I have a noise like that but manny people who look at it while I'm going reverse, said my differential might need oil or needs to be replace!!!??
Old Jan 24, 2012 | 10:33 PM
Lena's Avatar
its u joint... glad thats all it is
Old Jan 24, 2012 | 10:34 PM
Lena's Avatar
dc im going to get my brake caliper thru u guys i believe
Naween Zohab
Nov 10, 2015 03:56 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Odin
Sep 26, 2015 06:56 PM
altydog
Sep 20, 2015 07:37 PM
May-39
Sep 6, 2015 01:05 PM
