AC Magnet Clutch Bearing info
Old Jul 13, 2025 | 03:11 PM
prcnctoyo's Avatar
Anyone have any cross reference info on Toyota part # 90099-10135? It's the AC magnet clutch bearing. My local dealer parts site doesn't show it as being available. A google search result show a couple available on ebay. Rockauto lists a few but none have the part # cross referenced. If I do a Rockauto part # search, I get one result that is not in the list for my year.
Thanks for your help.
Old Jul 13, 2025 | 05:32 PM
millball's Avatar
Not in the SKF master list but look the Toyota number up in that list anyway.
The numbers surrounding it are all fairly common double sealed ball bearings.
One of those other numbers might be of suitable dimensions.
Your old bearing may well have an identifying number on it
Commonly available bearings are almost always specified for uses like this.
No reason to use any oddball type.
SKF_bearing_master_interchange_2009.pdf
Old Jul 17, 2025 | 06:16 AM
scope103's Avatar
is there something wrong with the eBay result? https://www.ebay.com/itm/352948394305
(Getting the correct SKF part might be cheaper, if you can determine which one to get.)
Old Jul 17, 2025 | 01:37 PM
prcnctoyo's Avatar
The ebay match bothers me because they don't include a pic of the actual bearing, just a pic of the toyota part #. It would probably be fine but then again. I also found the ones in this link. Each of them reference the toyota part #.
https://rodavictoriausa.com/?s=40BD4...ct&dgwt_wcas=1
I'll probably go with the NSK bearing.
(I was hoping Jimkola would see the post and reply. He had offered in another post to look up bearing info. He is not accepting PMs any more.)
foppert
Apr 7, 2016 12:47 PM
muddpigg
Oct 26, 2014 04:00 PM
deepmarsh
Feb 17, 2014 10:44 PM
fatboysam
Sep 25, 2013 06:34 AM
Corey Barlow
Aug 1, 2012 08:05 PM
