AC clutch bearing question
Old Oct 25, 2014 | 06:07 PM
muddpigg's Avatar
Guys,
I have still not found my FSM even with all the boxes unpacked with more to go.
So a newb question.
How to remove ac clutch?
Prefer to do so on the 4rnr as it blows cold.
If anyone has an e-copy of the FSM they don't mind sharing please help a bother out.
Thanks in advance.
Old Oct 25, 2014 | 10:49 PM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...12compress.pdf
You want to remove the A/C clutch from the compressor? I don't understand "Prefer to do so on the 4rnr as it blows cold." "Blowing cold" sounds like a good reason to NOT remove the clutch.
Old Oct 26, 2014 | 04:39 AM
JasonYota's Avatar
Might be stuck on? Blowing cold air all the time
Old Oct 26, 2014 | 06:00 AM
wyoming9's Avatar
Red face
That would be an electrical problem not a clutch problem.
The power to the coil is not being shut off.
Like all other things electric I guess a surge could weld the contacts like a starter .
I never took one apart now I am curious just how they do work.
What happens if you just unplug it??
Old Oct 26, 2014 | 12:43 PM
muddpigg's Avatar
Got noisy Friday. Was blowing really cold at time. So would think that AC on the bearing wouldn't make noise. But AC cycles. Have noted oil/grease seeping out between the parts of clutch, so thinking bearing going out.
Old Oct 26, 2014 | 12:52 PM
wyoming9's Avatar
Red face
That belt should be by it`s self remove it till you get it fixed..
Depends on the model of compressor some had a snap ring some had bolts in theory it should come off .
In real life most times it is stuck and a puller is needed being careful not to break anything .
Just where you live plays a big part in how bad it is stuck.
Old Oct 26, 2014 | 04:00 PM
muddpigg's Avatar
Yeah, pulled the belt off. Was trying not to pull compressor don't think there is room to use a pulley puller with it mounted. There is a 12mm bolt on the shaft. Just need to know if there is a snap ring or not.
Will research
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
