1988 22RE Throttle Position Sensor Behavior?
Old Sep 28, 2025 | 10:58 AM
jamesqf's Avatar
5 Year Member
Trying to track down problems with my '88 pickup*. Checking the TPS, I see resistance between E2 and TPA going from about 80 ohms when closed, increasing as I gradually open the throttle, until it goes to infinity at about 1/3-1/2 open. Shop manual says it should be 3.3K - 10.0K at wide open throttle. Does this mean my TPS is toast? If so, would that cause my problems?
Also the check engine light is now lit, and I get a TPS code 4.1 (and a VSS code 4.2), which I didn't before taking a bunch of stuff apart for testing & cleaning.
*Rough running, no power, won't go above 30 mph or so, Posted a question about it several months ago.
Answering my own question: apparently the E2-TPA resistance going to infinity is correct behavior. At least the new TPS I bought behaved the same way. (But was the later version with the rotor arms turned 90 degrees, so I couldn'rt use it anyway. Back to trying to figure out the problem...)
Vintage
Aug 6, 2025 05:25 PM
jsrusse11
7
Jul 27, 2014 03:53 PM
JCM4x89pu
Jul 22, 2008 03:29 PM
jrock
18
Apr 28, 2008 06:17 PM
weakyota91
Mar 7, 2007 09:26 AM
