PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Overheating 22R-E, Possible Bad Head Gasket?
  2. Is their a Repair manual on how do a Total Rebuild/ Overhaul 91 pickup 22re?
  3. Fail combustion leak test
  4. Starting issue (5spd)
  5. 1989 1/2 4Runner
  6. 22re Vacuum Line/Hose Question
  7. interior switch paint and markings
  8. charge system issues 22R
  9. Using the 3VZ-E to it's full potential?
  10. 22RE Suspect ECM and closed loop ops
  11. 1994 Toyota pickup project.
  12. Clutch Woes
  13. W40 to W58 Transmission Swap Information
  14. 89 22RE 4x4 2WD Idle surging
  15. Looking to buy
  16. New 4runner help
  17. tire switch 1987 DLX
  18. 1986 22rte another start and die issue......stumped
  19. Frame replacement
  20. 1st Gen Rear Bumpstop Upgrade
  21. Low Fuel Gauge
  22. H4 conversion LED bulbs
  23. 22re sensor
  24. 1987 PU Resto
  25. Overheating 3.0
  26. 3.0 vze Valve Spring Retainer
  27. How to Dissable Fuel Pump 1995 4Runner
  28. Muffler Replacement?
  29. Factory Service Manual - pdf format?
  30. Made a big mistake....
  31. '88 Pickup 2wd 22r no-start, electrical problem
  32. remove/install wires 22R fuse block
  33. Removing engine
  34. Cold temp gauge
  35. Custom Idler Arm -
  36. Drive Shaft bolts and nuts
  37. 22RE Oil Pan Resealing with FIPG Questions
  38. Help!
  39. Tail lights and markers stay on
  40. Engine rebuilt
  41. 95 4runner 4wd wont engage - Help
  42. Back pressure
  43. Cleaning up an 88 Pickup
  44. Engine fuse- 22R
  45. 4runner body swap wiring questions
  46. 89 2WD rear issues?
  47. Having trouble with my transmission swap wiring
  48. hot and cold starts fine. problem with warm start
  49. SAS third member question
  50. 3.0 to 3.4 or new heads/gaskets
  51. Roof top tents
  52. Water Pump Bolt/Nuts
  53. How to Scope a MAF Sensor 3VZ-E engine
  54. 4runners and pickups for sale on BAT
  55. How does the 22R-E prefer to drink Seafoam?
  56. 93 pickup door hinge mount
  57. 3VZe runs great without AFM...?
  58. R22 1986 R5D Intermittent Stalling
  59. 3vze coolant temperature sensor
  60. 95 4runner 3vze: start/relay phantom electric, help please
  61. Rumbling after OME Lift?
  62. Starting Problems
  63. Crankshaft Pulley Bolt Threads - help needed
  64. Toyota 4Runner 3VZE-T #Turbo˟˟˟˟car build
  65. Oil in intake manifold
  66. 1st gen 4runner rear cargo rust repair
  67. OEM Control Arm Bushings Part Numbers
  68. where did these bolts/nuts go on my 87 4Runner
  69. Battery keeps dying on 92 Yota
  70. Clutch/transmission issue on 93 4x4
  71. 89 speedometer gear
  72. 1988 2wd Xtracab 31s on stock suspension
  73. Engine doesnt warm up!
  74. After replacing New brakes, roter will not turn
  75. cel flashes and gives code 24 & 42
  76. Front Bumper
  77. 1994 Transmission down shifts out of the blue
  78. 94 22re 4cyl, looking for maintenance help in Atlanta
  79. o2 (air/fuel ratio) sensor interchangeability 3VZE
  80. 1990 4runner trans issues
  81. 88 Toyota 22RE auto trans leak
  82. Heater unit cable control help...93 yota pickup
  83. Gear swap from 86 4runner to 2000 elocker
  84. 22RE theoretical efficiency question
  85. Weber 32/36 LARGER or SMALLER idle jet??
  86. ECM fuse blown, (+) short on O2 circuit
  87. 95 pickup 4wd v6 radiator question
  88. Code 52 3VZ-E no signal to ECM
  89. 4Runner suspension and tire Q
  90. 22re coolant hose question
  91. '86 4rnr: removing rear gate window seals?
  92. 1988 toyota 4runner rebuild
  93. 87 Dually resto
  94. Possible Head Gasket leak with no symptoms....??? Only light smoke
  95. Request for help - Will first gen Tacoma Double Cab floor mats fit first gen 4Runner?
  96. 22RE - valve noise and O2 sensor
  97. Looking for door panels - 1984-1989 4Runner
  98. 22re injectors
  99. Modded door chime
  100. UPDATE: 22RE oil consumption
  101. 87 4x4 tranny swap help
  102. 1993 3vze drivability issue
  103. Help with locking hub part
  104. Suspension
  105. Loud knocking at start up, goes away and starts again at higher rpm
  106. Intermittent start
  107. coolant in upper intake manifold
  108. brake pedal goes to floor. replaced master cylinder
  109. New to the Toyota game
  110. Exhaust question
  111. 87 4Runner Coastal 22RE Build
  112. 94 22re 4x4
  113. 1992 Toyota 22re 4x4
  114. HELP, 1st gear not engaging, 3vze 4wd automatic trans
  115. 89 pickup: need new LH chrome mirror
  116. 3vze idles at 2000rpm after rebuild
  117. '91 22RE - oil consumption between oil changes
  118. 4X4 Fenders
  119. ball joint spacers 93 t4r
  120. Failed smog on 1995 22RE with odd results. Any suggestions?
  121. Auto off headlights?
  122. 87 22r Pickup stalling
  123. Vibration let of pedal
  124. 1987 4Runner 22RE no fire on #2 and motor will not run by itself
  125. speedometer housing size?
  126. which A/C compressor, 94 P/U 3vze
  127. power steering pump pulley
  128. 87 4Runner - Anyone have experience replacing a rusty factory sunroof?
  129. EGR valve connector question
  130. Please help! Gas smell
  131. 92 22re no start
  132. Power steering pump change now getting weird noise. Thoughts suggestions?
  133. SR5 Vertigo seats upgrade
  134. '90 pickup door hinges
  135. Worth the time/cash? 1995 4R 3.0 4x4
  136. "La Michoacana" - Engine work - ADVICE NEEDED
  137. 89 3.0 5 speed issues
  138. 95 4Runner. Cranks, no spark no fuel 3VZE 5 Speed
  139. Rear Coil Springs- will 3rd gen springs fit a 2nd gen?
  140. ARB Bumper installation and Winch install (92 Pickup)
  141. 1993 rear tube bumper
  142. How much weight will a 1991 4runner carry on the roof with no factory rack system
  143. 22re carb
  144. Factory removable top mounts?
  145. W56 Grinding over 50mph
  146. Question regarding oil pan gaskets (3VZE)
  147. 94 4 Runner Won't Start, with Details
  148. Forward gears in neutral & reverse
  149. New head install, not running right
  150. 22r new Weber 32/36 backfire (ruined air filter)
  151. 93 22re Shutdown while driving
  152. IntermittentStartingProblem, '93Truck
  153. cutting the top off a 1st gen 4Runner : )
  154. Maybe a WTB thread
  155. 94 pickup RAIN electrical short
  156. Wont start- oil temp, battery, and brake on dash
  157. Brake MC overfull after sitting
  158. 94 4x4 automatic
  159. Jumping out of gear.
  160. Seat swap
  161. My 1991 4Runner Progress Thread
  162. HELP Identifying Leaf Springs
  163. Looking for definitive answer on spindle/CV grease
  164. Best Rock Slider?
  165. Throttle Opener 4Runner 1993
  166. Leeks
  167. Leeks
  168. Leeks
  169. Leeks
  170. Leeks
  171. volt meter/flasher issue
  172. 3VZE Severe Missfire after engine swap!!
  173. 3VZE Severe Missfire after engine swap!!
  174. 1987 22r New weber 32/36, what degree to set timing?
  175. 1992 Pickup Persistent Exhaust Leak
  176. Just found this bolt sitting in my oil pan
  177. Best way to handle driver side inner fender rust on 87 4Runner?
  178. W46 transmission doesn’t shift on/off after engine swap!!
  179. After Add-a-leaf, spring and axle not lining up.
  180. 22RE coolant issue has me stumped
  181. No start just clicks
  182. 89 3VZE Auto. Rough Start and Dies.
  183. 90 runner washer pump wiring
  184. 1st gen dash panel lights on
  185. Engine swap no start
  186. Back window
  187. Poor mpg on a 22re
  188. W56B does not shift smoothly
  189. 1990 Toyota truck twd
  190. 3.0 cat back system
  191. Will the 3.4 crossover fit a 3.0
  192. Mud Flaps PDF
  193. Headgaskets Replaced, now crank no start.
  194. 1st gen driver seat updrade
  195. Distributor ruined by blown motor? 91' 3vze
  196. Rear window wiper- is this correct?
  197. Does not start when warm on re-start
  198. Automatic to Manual gears
  199. Power windows
  200. 93-95 Rear chrome bumper question
  201. A340E auto Trans Solenoid #3 replacement
  202. tailgate letters colors
  203. Load limit
  204. Oil Cooler Question
  205. '92 22RE - trouble starting and stalling while stopped
  206. Front End Squeak
  207. Did replacing rear ring and pinion brake the front diff?
  208. Did replacing rear ring and pinion brake the front diff?
  209. The ticking sound
  210. 89 4Runner Power Window Master Switch Disassembly
  211. ABS actuator leaking fix
  212. No heat
  213. 22re limp mode?
  214. Sound while turning engine
  215. 93 pickup bucking using 4wd in reverse up an incline
  216. Is MOOG now rebranded chinese junk?
  217. 93 w55 won't downshift while moving
  218. New tires for my truck
  219. 90-95 reproduction pickup bumper question
  220. Oil filter drain back
  221. No Hazard lights but blinkers work fine (88 4x4)
  222. upgrade HP - original drivetrain
  223. Throttle Body coolant Flow
  224. 1993 T100 V6 - "bouncing" throttle (not idle)
  225. New Bed for 1988 Toyota Ext Cab 4WD PU
  226. 1990 Toyota pickup won't turn over
  227. Multiple switch controller ideas?
  228. Warn combo kit
  229. 22RE cranks but won't start
  230. Advice- Stock bed or faltbed???
  231. Two caps on intake?
  232. 1995 4Runner interior in 1992 truck
  233. 1990 toyota 4runner 3vze 2wd issue
  234. Power window motor binding
  235. 22RE Throttle Body (Before & After)
  236. New Truck, Trying To Figure Out Noise (Video Included)
  237. Where Can I Find a Quality Stock 2RE Cam ?
  238. Headgasket
  239. Fresh paint
  240. Fresh paint
  241. Restoration of 86 gas turbo 4x4 sr5
  242. Engine cuts out. HELP!!!
  243. Back windowsc
  244. Try To Accelerate = Continuous Up/Down Revving
  245. 22re noise driving me nuts!!!!!
  246. Suspension
  247. 22re head replacement
  248. 92 extended cab - things to look for?
  249. cold start time switch on 89 4runner 22RE
  250. Is the 84-88 tail light assembly interchangeable with the 89-94 assembly?
