No start just clicks
Old Dec 22, 2019 | 09:21 AM
Fitter527's Avatar
Bought a 93 pickup sr5 4x4(3vze) a few months ago.went to start the truck this morning and all i get is fast clicking sound from the passenger side and wont start.pressed the clutch delete button and tried to start the truck but just a single click and still no start.
i have been going through multiple threads on here and havent found anything similar?not sure where to start.
Old Dec 22, 2019 | 11:56 AM
scope103's Avatar
What would be the simplest explanation for a problem like that? Yup, low battery. Put your multimeter on the battery posts. If below, oh, 12.3volts, you need to hook up a charger.
Old Dec 22, 2019 | 04:53 PM
Fitter527's Avatar
I checked the battery with a multimeter and the battery is fine.truck was turning over at first but wouldnt start.now it wont turn over at all,just the clicking.i hooked it up to the charger and still just clicking
Old Dec 22, 2019 | 05:22 PM
RAD4Runner's Avatar
I do not believe that you could not find similar problem on this forum.
A problem well-stated is a problem almost solved.
Exactly what and where is clicking?
Originally Posted by Fitter527
I checked the battery with a multimeter and the battery is fine...
We do not know your technical level is.
EXACTLY how did you determine that battery is fine?
Old Dec 24, 2019 | 05:04 PM
Fitter527's Avatar
Got'er goin.been busy last couple of days so this morning i decided to have another look.ill admit i know very little about electrical but mechanical i am quite knowledgable.
i started with the battery.checked it with an analog multimeter and it was a little low prob from trying to start it the other day.hooked it up to the battery charger.
started looking at the wiring coming off the battery.followed the main positive wire going to the starter.at the connection to the starter solenoid there was some green corrosion on the ring terminal.i peeled the electrical tape off and it was actually quite clean underneath.so i cleaned all the corrosion off,retaped and put it back on.
I turned the key over and it started right away.
the other day when i couldnt get the truck to start it was -13°C.today was +2.maybe my battery doesnt have enough CCA?
thanx to all who replied
ezucker
Apr 11, 2013 08:31 AM
kdogy313
Jun 27, 2010 08:16 AM
ayoung101
Sep 30, 2009 11:26 AM
staticx
Sep 8, 2008 01:58 PM
Whitey13
Sep 7, 2008 07:50 PM
