3vze throttle body
Old Nov 30, 2019 | 09:35 PM
Levi8282's Avatar
3vze throttle body
I’m in need of some help, I’ve taking my throttle body off just to clean it and now I can’t get my truck to run, it will start up then die a few seconds after, I can’t find what did wrong I can’t find any vacuum leaks I’m getting fuel and spark, I’m just lost and need some possible ideas it could be
Old Dec 1, 2019 | 07:02 AM
scope103's Avatar
Welcome to YotaTech.
Is the induction plumbing all hooked up? "start up then die a few seconds after" is the classic sign of a VAF-COR problem. If the VAF isn't connected, the FC never closes, and the fuel pump stops as soon as you let go of the key.
If everything is hooked up, jumper FP to B+ on the diagnostic connector. If it starts and runs then, you DO have a VAF-COR problem.
Let us know how this mystery turns out.
Old Dec 1, 2019 | 04:04 PM
Levi8282's Avatar
Everything is hooked up for sure, I don’t know how to run the jumper, I’ll have to find a video for it, but today I held the flap open for the vafm manually and the truck ran for a bit longer and still shut off, I think it’s the pigtail running to it, I have a replacement, but I’ll replace if I have to, after I attempt the jumper idea. I appreciate the help and I’ll post what it was after I figure it out. thanks for the help
Old Dec 1, 2019 | 05:24 PM
scope103's Avatar
http://web.archive.org/web/201003261...87fuelpump.pdf
This is the '93 manual. Very early 2nd gen's have a different diagnostic connector (still same functions). But since you didn't tell us your year/model/ etc., this is all I know.
Old Dec 1, 2019 | 06:33 PM
Levi8282's Avatar
Thanks for the diagram, I have 93 automatic 3vze
Old Dec 2, 2019 | 09:11 AM
Levi8282's Avatar
Well the jumper didn’t change anything, and when I give it gas it dies off faster, I’ll check for a vacuum leak, but haven’t been able to fine one
Old Dec 2, 2019 | 10:23 AM
scope103's Avatar
Well, let's make sure the jumper was done correctly. Did you HEAR the pump start? (It shouldn't be very loud, but in my garage I have no trouble hearing it while standing at the jumper. If you're on the side of the freeway, that's a different story.)
Also, you can check flow easily. Replace the fuel return line from the FPR with a 6mm clear vinyl hose to a suitable container. With the jumper in (and key-on), I get about 1/2 liter/min. Then try to start it (be careful; don't let the vibration knock over your container!!). Your return flow should drop a little. If it goes to zero, your pump is not delivering enough flow. Weak pump, clogged fuel filter, clogged line, ....
(The return line is low pressure, so you can pull the hose then just replace it. If you disconnect a high-pressure line, you MUST replace the crush washers.)
Old Dec 3, 2019 | 12:54 PM
Levi8282's Avatar
well she’s definitely getting fuel i hear the fuel pump kicking on and hear fuel running to the fuel rail, I loosened the bolt and turn the key to run and opened the switch on the vafm and fuel sprayed every where, I’ll go get a pressure gauge in the morning, but I notice if I give it gas it dies faster, so maybe the fuel rail could be messed up?
Old Dec 3, 2019 | 02:20 PM
wallytoo's Avatar
you chose not to follow good advice, by loosening a fuel rail banjo bolt rather than disconnecting the low pressure return line. now you need to replace BOTH crush washers on the banjo fitting that you loosened.
Twood
Nov 17, 2019 05:55 PM
Aircrue
Nov 1, 2019 05:16 PM
cbr600rx7
Aug 31, 2016 06:13 PM
dudeinhole
Jan 26, 2016 04:51 AM
p5supa
Jun 1, 2014 12:41 PM
