throttle body 86 4runner
Old May 13, 2014 | 05:20 PM
p5supa's Avatar
I finally started my truck last night and it ran for a good minute before it slowly started to die. I turned it off and started it again and it started to die quicker now it starts and dies instantly. I think it may be too a bad fuel filter but I'm also wondering about the vacuum lines I have a throttle body to a 22ret and everything else on my truck is for a 22re I know they are different but would it make a difference on how the truck runs?
Old May 13, 2014 | 11:21 PM
wyoming9's Avatar
Red face
It could but more likely a fuel filter problem unless for some reason the AFM switch is not keeping the Circuit opening relay coil energized to allow the fuel pump to run.
If you have a huge vacuum leak this could happen. Leaks or cracks in the air intake tube.
Why go with the 22RTEC throttle body was it all you could find??
Old May 14, 2014 | 12:00 AM
p5supa's Avatar
How can I check that switch? I have a full 22ret motor in pieces and it's the throttle body off that one I could just use the one of my old engine. But if it doesn't make a difference then I won't.
Old May 14, 2014 | 12:21 PM
wyoming9's Avatar
Red face
Multimeter looking at the AFM plug removed pins 1 and 2 open with the flap closed closed with the flap fully open
Old May 15, 2014 | 01:00 PM
wyoming9's Avatar
Red face
Make any progress??
Old May 15, 2014 | 07:34 PM
p5supa's Avatar
Make any progress??
Not yet plan on going out there tomorrow. Cause the truck isn't at my place I can't get out there all the time.
Old Jun 1, 2014 | 10:56 AM
p5supa's Avatar
So it's not the afm it started today ran for a good minute then slowly started to die and couldn't get it to start again I know there has to be something simple I'm missing
Old Jun 1, 2014 | 12:41 PM
p5supa's Avatar
I think my alternator is bad causing the engine to draw off only the battery and then not inject enough gas making it miss then it won't start again cause the battery is drained
smthwsn357
May 1, 2024 07:28 AM
kazuya2416
Apr 5, 2024 02:17 AM
Jun 1, 2021 01:51 PM
raiderhawks00
Jul 8, 2015 06:23 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
