- questions about my 86 toyota?
- Is it Safe...
- HELP!!! in desperate need of help massive coolant leak
- My 86 Manual Swap ->
- torsion bar
- what model/trim pkg is this cluster from?
- Got a Recall Notice
- 94 runner brake light
- sec. gen. 4runner suspension
- Fuel light ?
- 3.0 Head Gasket Replacement Write Up??
- New Guy
- second gen. 4runner suspension
- 88 missing cold = bad head gasket :( Parts questions...
- Failed emissions on a fresh motor? Please help
- question about new shocks
- My 1990 toyota pickup 4x4 pickup project! Check it out!
- rebuilt engine, now shes getting hot! 3vze
- 88 Missing and sounds like its running on 4 cyls cold? HELP!
- 4Runner vs. Jeep CJ
- 93 v6 pickup sucks gas
- Adjusting the AFM
- I think I found my problem!!!!!
- assembled 3rds ?
- Where to mount Antenna
- Powersteering gear box leaking
- changing add to manual aisins
- Odd Codes
- 94 4runner 3.0 auto Locker? or no Locker?
- O/D off light is on crack. (86 PU)
- a/c removel
- Dual Batterys?
- what is this?
- 3.0 is really slow
- 1994 4runner jumping/hesitation plz hlp!
- My automatic hubs 4x4 arent working
- 95 toyota sr5 3vz v6
- Which year to remember for classic 4x4's
- sr5 cluster into 93 pickup
- Sorry, another rough idle post on 22re
- Need advice on LSD's
- Cruise Control Shock sensor?
- Whats all involved with bigger tires?
- I'd have to follow...
- Nothin But Money
- I just acquired a 5M-GE
- Shocks
- Help ! New 3vze rebuild is overheating.
- I Cannot find a FSM for 87 Pickup!
- My new ISR
- Questions on front diff spinning correctly?
- remove axle studs a good idea or stupid one??
- After market TPS
- What am I missing???
- Finding odds and ends...
- Very strange happenings with the runner...
- The Lowdown
- HELP fuel system questions
- HELP Cooland in the intake manifold!
- Broken valve cover stud
- pushing the limits of IFS???
- Stuck, and I mean STUCK!
- 2" Body lift
- tricking the ECU
- Carburator
- strange idle problem
- Banging/ jerking in 4wd
- 3.0 headache
- LandCruiser Coils in rear for 92 4runner
- Will a '95 combo switch work in a '91??
- removing parts of the dash?
- 22re been sitting long time
- Power Steering/ ABS actuator problem???
- ball joint spacers
- bad buck??? engine/trans mount?
- Soft 8/D windows on 2nd gen 4runner
- New additions to the Runner
- OME spring ?
- Ball Joint Help!
- what do you all think? Help me out
- I need a rear BUMPER
- Timing chain replacement question.
- Invalid VIN!!
- 2wd diff question
- '92 toyota 3vze engine trouble when warm
- Welded front DIF????
- HELP!! my runner died :(
- 93 2wd doord fit an 89 4x4 both std cab
- Clogged breather or bad seal?
- 1994 4 Runner 5 speed swap cruise problems
- trade lift for truck?
- Which 22re?
- Good idea, bad idea?
- Head Gasket Recall?
- Selling my complete custom stereo system
- 4WD Not Working
- Rear anti-lock light on
- Still having problems with my 4runner
- Front heater defrost setting
- High miler club
- Overheating?? Need help!
- How for a 3.4L Swap
- What Toyota Should I Buy? Mines about to be lost forever...
- Hooray Clutch!
- Help with inner/outer wheel bearings please
- fuel gauge incorrect when idle
- 1987 Carb vacuum ports capped but still have lines?
- New parts place for the Houston Homies!!!
- Rear slider replacement
- Looking for advice - Winch Mount Ideas...
- Gasket kit reccomendations
- Pic or diagram of heater box?
- temperature?
- Newb Question
- 4WD clunking noise*
- How hot does your 3.0 run? Poll. Bad thermostat?
- Roommate totaled my 4-runner time for a new one
- 22re Runs very rough after driving on highway
- Dialup beware! Videos
- reseting Timing not making a difference with rpms
- A Bad Automatic Transmission Mount may be causing My Vibration?
- new cv axles?
- my build up
- Hac/Fab 86 4runner
- rebuilt 22re doesnt have power to drive down freeway
- ARB Front bumper.. bolt size
- 1991 Pickup: To Live or To Die?
- Fuel injector diagnosis possible without running engine?
- clutch pedal on the floor
- speed sensor removal (rear diff)
- 94 4runner, loss power with fan on
- Where to find an Auxfuel tank for 4runner
- Power steering fluid and ATF dexron 2 different?
- 90 runner 4wd problem
- Engine replacement question
- Replacing the Stock Coil on 22RE
- The ??? of the Day Surf Diesel in a 92 4Runner 3.0
- Sprung a leak!
- Dome light LED question
- Sweet Tire Inflation Idea
- Got a parts truck in WA?
- need help choosing a new engine
- funky name for grease
- Lug nut torque specs
- 4wd not engageing
- where is the temperature sensor?
- Driver Side Door Lock...
- Main bearing installation question
- Strange leak under dash???
- New here with questions on lockers
- auto to manual transmission swap??
- '91 Pickup inconsistent idle
- well well well, look what UPS done dropped off fer me
- 1988 3.0 4runner injectors?
- Full fluid change from tran / tran case to diff. What type?
- 4Runner Accident!
- 12 gauge Shotgun...
- what could it be?!! please help!!
- Help! Need help adjusting TPS, Faulty?
- HOW to install a tach in a 1987 Pickup 2WD
- 22RTE vaccum hose on valve cover. where does it go!?!?
- big choise to make
- emissions high NOx.... again? I know....
- Steering Column Transplant
- tranny
- Busted door going through tahuya in the snow
- Pwr steering fails when cold? Right only?
- Racked by guilt...I must confess
- Transfercase?? Is it bad?
- Whats goin on with my Yota?
- Cause of intermittent rough idle at start-up?
- Rims And Tires Help
- Bumper Blueprints???
- Manual Swap?
- Mr Bill Says................................
- TC idler arm review
- Rear coil instal and 2" body lift
- Somebody on here has a 4Runner with no bed....
- '94 Pickup 22RE leftovers
- Are upgraded V6 calipers ok behind 15" rims?
- ATTN: 1st gen 4Runner owners.
- jeep tj front coils in the rear of a 93 runner?
- What kind of transmission is this?
- where should i put a cd cganger into a 1st gen runner?
- 3.4L, 4.3L, or repair 3.0L? cheapest way out?
- Advice for 1991 PU leaf springs
- name this part please :)
- Looking to add a switch to operate my sliding glass from inside the cargo area
- trail rig/daily driver vs a trailer queen
- look at these spark plugs!!
- Yota is like a pogostick!
- Is it my head gasket
- Bad fuel pump or fuel pressure regulator?
- home made rock sliders, what's the angle?
- Cold start injector..bad?
- Fender Bender
- 3.0 finally running
- e-brake switch?
- transmission issues?
- trouble codes help
- Running Cold. Thermostat open? OEM thermostat replacement?
- 93 O2 sensor woes
- what do I need to remove to weld?
- Rear Bumper slapped together in 4hrs!
- Installed headers, now code 71
- never seen one of these before
- Got scoop or cowl hood post picture
- budbuilt drivetrain lift
- need dash
- swapping the ADD with a a non add carrier
- 90-95 4runner racks
- good buy?
- Vacuum Line Confusion
- How much abuse can the parking pawl take?
- 1988 yota crank ???
- 3vze timing issue....
- Not getting FUEL??
- Parking Brake Issues
- Going on for 4 months and still havnt figured it out. any ideas
- 3/4" wheel spacers- rubbing?
- 1986 22re Engine Miss
- adding cruise control in 884runner
- Like I Need Another Project...
- cooling problem
- Finally ordered my parts =]
- 4wd problems please help!
- 22re oil getting into intake after rebuild?
- Please Help
- a ? about 3vze diagnostic codes
- Q for cold weather owners-22RE fuel issue
- Rear wiper mod
- 1995 4runner idling wild and throwing some black smoke
- Block options
- New ignition cylinder lock activates buzzer
- I know.....ANOTHER HEAT QUESTION !!!!!
- Mysterious Black Box
- ??? on swapping from A.D.D. to without
- Charging gauge / battery question
- removing pcv baffle in valve cover 22re
- Rolled my truck need help figurin out whats wrong with engine.
- 3VZE clutch replacement writeup/ advice?
- headlight wiring upgrade
- rear window works once every 2 weeks when it wants...
- I have no horn...
- Which is better? ISR mod or K&N Cold air intake?
- oil pump adjustment screw ????
- 3rz?
- Noise from front end when braking
- my first toyota! (56k make a sammich)
- Custom Truck Bed Storage?
