Lug nut torque specs
Old Jan 20, 2009 | 08:47 PM
Matt16's Avatar
Do you torque them? I can't say I do, its too much hassle. I do feel I can approximate the heavy side of 80ft-lbs. Curious what you guys do.
Strangely enough, Discount Tire's website shows 170ft-lbs for the 2wd Toyota truck DRW (<-- ??... as opposed to SRW???). That seems like a lot. The Porsche Carrera GT is whopping 407ft-lbs compared to Ferrari's pathetic sub-100s... and were still talking lug nut torque!
Old Jan 20, 2009 | 09:13 PM
twitchee2's Avatar
manual for my 3rd gen says 83. i go with 85 cuz its nice and round. not to tight thought, the studs dont like that much torque.
Old Jan 20, 2009 | 09:26 PM
darksoldier313's Avatar
i torque every wheel i take off believe it or not but uneven torque can cause warped rotors not to mention its a nice safe feeling knowing they r torqued
Old Jan 20, 2009 | 09:30 PM
and 170 sounds a lil extreme for what yr 2 wheel??
Old Jan 20, 2009 | 09:34 PM
Yotapowa's Avatar
I torque mine with the SR5 4 twin spoke rims to 100 ft lbs. Its a good idea to torque, because if you dont and your unlucky your lugs will loosen! It happened to me, but i discovered it before my wheel fell off thankfully. I used an impact gun that time, now I only use a torque wrench
Old Jan 20, 2009 | 10:25 PM
space-junk's Avatar
Coming from the import scene ive found that with ANY aluminum rim, only torque to 75ft. lbs. so thats what i follow with my stock SR5 Alloys...
my steel wheels i wail on at 90ft. lbs...
and for the record, i ALWAYS torque my rims... just a good habbit to get into...
Old Jan 20, 2009 | 11:40 PM
nv4runner's Avatar
Last time I looked it up on Alldatapro.com the lug nut torque spec was 75 ft. lbs. for my 4runner. I torque them with the 80 ft. lb torque stick. I've rechecked them with a torque wrench and one of the sticks is pretty accurate. It really depends on how much time I have to put the wheels back on though.
Old Jan 21, 2009 | 12:10 AM
DudeBud's Avatar
wth 170ft lbs for a 2wd toyota thats cant be right unless maybe the 1 ton dully model. and 407ft lbs for a Porsche that cant be right.
Old Jan 21, 2009 | 12:51 AM
Matt16's Avatar
I think its probably the dually, but I don't know. Its consistent with the motor home numbers and many (most?) one tonne duallies were used as motor homes.
The Porsche GT isn't your average tiptronic-posermobile driven by a business-boy in Gucci sunglasses.
[youtube]http://www.youtube.com/watch?v=vE_WqdKbTvY[/youtube]
Old Jan 21, 2009 | 02:04 AM
nosfanatic2006's Avatar
Gah, that's one of my most favorite episodes
Old Jan 21, 2009 | 04:42 AM
waskillywabbit's Avatar
80 ft lbs on alloy
100 ft lbs on steelies
100 ft lbs on wheel spacers with a drop or two of red loc tite
Old Jan 21, 2009 | 05:39 AM
mastacox's Avatar
Oh its correct. Its because the Carerra GT doesn't have a lug pattern, it has a large single hub that screws on like an F1 car. The car comes with a special little gearbox wrench that attaches to the wheel and multiplies your torque, so you can put out enough torque to attach the wheel properly.
See:
Old Jan 21, 2009 | 06:16 AM
mt_goat's Avatar
I've been torquing to 85 ft-lbs with my wheels.
Old Jan 21, 2009 | 06:40 AM
they come factory with a knock off?? dont know if i much care for that
Old Jan 21, 2009 | 03:10 PM
Matt16's Avatar
what's a factory "knock-off"?
Old Jan 21, 2009 | 04:16 PM
knock offs-wheels with one lugnut more popular with the dayton spoke rims had a set on the beemer for a while they call em knock offs because they come with a three spoke key that u smack with a hammer to tighten or loosen but they look cool none the less
HiLuxer
Jan 6, 2016 11:34 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
dbollier123
Sep 29, 2015 05:23 PM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
