where is the temperature sensor?
Old Jan 20, 2009 | 07:22 PM
xzyragon's Avatar
Ya...
I ordered one on accident, but if it goes to the radiator, I will probably need it. Just want to know where it goes
Old Jan 20, 2009 | 07:30 PM
just a 22re's Avatar
im guessing on your 22re aye? well look for the upper rad hose fallow that to the intake then look right inder it you should see two sencers right there have fun!
Old Jan 20, 2009 | 07:33 PM
iamsuperbleeder's Avatar
ummmm, you'll probably going to find 3 sencors on that puppy..
what one are you talking about; for the gauge, the ECU, or the cold-start valve?
the gauge is a single wire, located between intake runner 2 and 4 on the intake manifold, up close to the cyl head
the other two face forward and have a clip-in plug that have 2 wires
Old Jan 20, 2009 | 08:55 PM
abecedarian's Avatar
temp sensor... hmm... at least 3 sensors I know of refered to as temp sensors.....
the one for the gauge is on the intake manifold, threads in vertically, behind the thermostat, between #2 and #3 intake runners, has one wire....
the one for the ECU is on the intake manifold, but up in front, and threads in horizontally from the front of the engine and is usually 'green' in color (the black one should be the cold start injector time switch)
the last one is inside of the AFM and is not replaceable by itself.
Old Jan 20, 2009 | 08:56 PM
*double post*
Old Jan 24, 2009 | 08:57 AM
Bako88's Avatar
Abe- I want to test the sensor that sends to the ECU. I had to replace it when the original broke in half during an engine replacement. I have been having problems since and want to rule out that sensor. Can you help with info on how to test? Do I compare ohm reading cold and then norm oper temperature?
catusphile
10
Jul 27, 2020 02:38 PM
Kreedy1
Sep 8, 2015 06:33 PM
izzmee
Aug 17, 2015 10:20 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
