Ball Joint Help!
Old Jan 23, 2009 | 12:21 PM
pathfinder's Avatar
Ball Joint Help!
Hey guys,
in the middle of doing upper and lower ball joints on my '90 4x4. I've managed to get the driver's side done with a pickle fork. My question is do you have to press the ball joints back in or is tightening the nut sufficient? I don't really have any way to press them in...if I tighten everything up as much as possible can it be done when I get an alignment?
Thanks!!!
Old Jan 23, 2009 | 12:53 PM
flashkl's Avatar
nope, they don't gotta be pressed in. Just torque it to spec and then check to see if it's loosened at all in a week, then a month or so.
Old Jan 23, 2009 | 01:17 PM
pathfinder's Avatar
Awesome, thanks!
Old Jan 23, 2009 | 02:27 PM
Matt16's Avatar
For studs found on the steering, I've always put anti-seize in the hole, then tightened the nut until the slots on the nut line up (in a vertical sense) with the hole in the stud. Then you put your cotter pin in and call it quits. No press, no torque wrench.
Also, I find pickle forks really suck on their own. I use a pitman arm puller in conjunction with the fork. Crank the puller until its tough to turn anymore, then smack it with the fork. Usually pops right out.
$30 pitman arm puller:
Old Jan 23, 2009 | 04:10 PM
ovrrdrive's Avatar
Torque to spec and put in the cotter pin and forget about it.
Old Jan 23, 2009 | 04:47 PM
abecedarian's Avatar
spin around 3 times, jump in the air and click your heels together then grease the joint...
... and check it periodically. If you put any grease / anti-sieze lube / etc. in where the joint mates with the arm, over time the grease or lube will migrate out leaving a void that will only turn in to free-play.
Old Jan 24, 2009 | 06:27 PM
pathfinder's Avatar
Well, spacers, shocks and four new balljoints are in. The pickle fork worked for three but the passenger side lower had to be grinded in half so I could get get the press I'd rented to work. Wahoo. DONE!
Old Jan 24, 2009 | 06:37 PM
flashkl's Avatar
w00t w00t w00t. Congrats
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
