What kind of transmission is this?
Old Jan 19, 2009 | 03:40 PM
frankentoyota's Avatar
does anyone know what kind of transmission this is.. I am told it is out of a 1990 toyota extra cab se. do not know the motor size or have the vin or anything but these pictures.. also is it possible to put a transfer case onto this and what would need to be done to do this.. thanks
Old Jan 19, 2009 | 03:47 PM
Bigblock's Avatar
It would probly cost more to put a T/C on that tranny than to find the correct one.
Bigblock
Old Jan 19, 2009 | 04:32 PM
well i have a g52 tranny and w56 tranny that are no good sittin in my shop as well as a transfer case for both of them so top and forward so i didnt know if maybe the back case would change out for one of those two? i am not really familar with how a transmission works though so i have no actual idea
Old Jan 19, 2009 | 04:37 PM
iamsuperbleeder's Avatar
a manual
Old Jan 19, 2009 | 04:42 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Looks like the one I have sittin here. Off of my 22re Celica.
Old Jan 19, 2009 | 06:14 PM
what year is your car?
Old Jan 19, 2009 | 06:25 PM
allnmstkn313's Avatar
W Series 2wd truck transmission, from a 4cly engine. Cheaper to start with a 4wd transmission than to convert.
toylocost's Avatar
It is a 1985. The 22-re trucks and Celicas used the same trans just different gear ratios.
Old Jan 19, 2009 | 06:41 PM
Old Jan 19, 2009 | 07:47 PM
Old Jan 19, 2009 | 07:52 PM
Even if i already have a w56 out of a 4wd with no good gears? is it only the extension housing that would have to be changed over to a transfer adapter or is there more to it than that? its basically what i would like to know
Old Jan 19, 2009 | 08:37 PM
Oh, didn't check all of the posts
The W 2wd and 4wd transmissions are the same, just with a different rear housing. Although the actual gear ratios may be slightly different.
If you already have a good extension housing gathering dust, by all means use it on the 2wd transmission.
Old Jan 19, 2009 | 08:38 PM
for the love of god, what year is your Celica with the 22re in it toylocost
Old Jan 19, 2009 | 08:39 PM
ok i just wanted to clarify that it would work with one of my transfer adapters. but can someone confirm this is a w55 or w56 or whatever it would be since im payin for it i want it to all fit together when i get it.
Old Jan 19, 2009 | 08:41 PM
haha my computer tends to piss me off alot by doing this..
Old Jan 19, 2009 | 08:45 PM
Pull the clutch off, and snap me a picture of the front bearing retainer and I'll confirm if it's a G or W series.
Old Jan 19, 2009 | 09:22 PM
i dont have it... i am going to buy it.. but if its a g series then would the g52 transfer adapter work also? because i got one of them layin around too..
Old Jan 20, 2009 | 05:12 AM
I just don't know about the G series, never bothered to repair one. I'd be interested in knowing though if you do go the G route, good luck.
Old Jan 23, 2009 | 03:18 PM
well so far its going ok.. all the gears are going to have to be switched over from the 2wd output shaft to the 4wd output shaft since most gears on the 4wd shaft were ground to nothing and of course it has to be diffrent gear sets so this is going to take me a little but of time for my first rebuild. but the extension housing off and putting the transfer adapter on it all bolts up so thats a good sign.. just to get all the internals switched from one shaft to the other and put back together.. i will post some pics later on
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
