PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 92 pickup cel code 24 and 25
  2. Air conditioning question
  3. 92 3.0 4runner fuel or electrical issue.
  4. 3vze won't run right with correct timing
  5. 91 4runner died warning lights rpm gauge drops and engine turned off
  6. 1990 4runner 3vz-e motor cam timeing
  7. Speedo drive gear
  8. New (to me) 4Runner, Wabfab built?
  9. New to the board - 87 22R 2WD running rough/backfiring
  10. magnaflow cat with 02 bung????
  11. help please
  12. Just went offroading...should I change fluids?
  13. 93 3.0 Engine Issues
  14. What Trips the CEL/Idiot Lights
  15. Gray/Brown Plug, Leaking
  16. A couple questions please
  17. Thinking Snorkle. Any Sensors?
  18. yet another CV boot thread
  19. Idiot Light Problems
  20. 95 4runner missing under acceleration.
  21. New Paint, after she's been so good to me for so long...
  22. rear window problem
  23. different gear ratios?
  24. Tranny questions
  25. 3vze problems
  26. torque converter wont stay locked
  27. no acceleration
  28. Antifreeze mystery
  29. Should there be lateral play in the wheel bearing?
  30. I want a 1994 4runner with a 22re engine!
  31. Ball joint spacer problem*
  32. 1st gen 4runner FSM download on Ebay
  33. ifs and cross over steering
  34. Gas Tank pinhole repair help
  35. Sr5 Cluster Accuracy
  36. Just did no cut zuk mod.......
  37. HELP trans leak w56
  38. 1993 4runner grill on a 1990 4runner
  39. 1991 4runner: replacing transmission
  40. EGR Delete Help - Line from charcoal canister to fuel tank
  41. ifs half shaft question
  42. Seat swap???
  43. sending unit install
  44. water temp gauge dont work well
  45. 7MGE AFM on a 22RE
  46. driver headlight wont work
  47. Stumble/mis? 22RE
  48. 22r Carb from Colorado
  49. 22re on 38" 5.29's or 4.88's
  50. What is this and how do I remove it?
  51. Herculiner roll in bed liner
  52. initial start checklist??
  53. vibrating a lot on highway 1990 toyota 2wd
  54. REBUILT ENGINE 22re HIGH COMPRESSION
  55. Powder Coating Cost
  56. Bucking
  57. How do I tell gearing on differentials?
  58. 265/75/r16
  59. intank fuel pump connecter
  60. Chevy spings with 235 tires ??
  61. 3vze cracked distributor cap
  62. Ported Vacuum switch broke
  63. RV and Pickup 22RE differences?
  64. Radiator help
  65. Transmission compatibility
  66. 3vze runs lean with no power
  67. 1986 heater control unit
  68. Code 51 & 21 on Check Engine Light
  69. new timing chain cover, coolant leak
  70. Slow temperature gauge
  71. What is that little plunger thing ...
  72. Stupid problem with heater controls that change position by themselves...
  73. Is this normal?
  74. what can you do to prevent rust
  75. what size tire should i get.
  76. WTB door control toyota 85980 - 89101
  77. 3vze starting issues
  78. 92 4wd manual to automatic trans
  79. What is the Standard Height of a 92 4Runner
  80. 85 RV air conditioning> 88 4runner retrofit.
  81. Stock Rear Window Switch..
  82. Coolant temp gauge goes to extreme high
  83. Shock Length Questions
  84. Best places for aftermarket mechanical temperature/oil gauges - 22RE
  85. 22re...no oil in the Oil filter?
  86. possible cracked head
  87. '88 4Runner coolant leak.
  88. Changing the fuel tank
  89. loss of power
  90. Throttle body cleaned.
  91. so i just bought this '92 4runner, but....
  92. 1993 Toyota 22RE sat for 2 years, trouble starting
  93. 92 pickup 3.0 cranks excessively before it starts!!!
  94. canopy
  95. 92 pickup possible transmission leak and speedo sensor problem (pics)
  96. Uhh Ohh. . . Headgasket? :/
  97. weird brake problem..
  98. 95 4runner shifting problems
  99. 89 22RE Stalls at lights ... problems seen no solutions verified
  100. 22RE AFM junkyard mod - more power
  101. San Diego Roll Call
  102. question on the isr mod
  103. need help on poor running 3vze
  104. 95 4 runner windshield into 89 Pickup?
  105. Pacesetter Auto header on 5 speed 1st gen 4runner Fitment
  106. Pics and update.
  107. My truck hates me
  108. Blazeland long travel track width
  109. Please help need advice
  110. Installing radio in '95 Base pickup?
  111. Trouble Codes rich/lean
  112. Fuel Sender Unit Discontinued - 87 4runner
  113. here we go again 1989 toyota 22r floods when starting cold
  114. Running the Fuel FilterVertical Issues?
  115. 86 4runner Intermitent CEL Help No Stored Codes
  116. High Beams Flash An Dont Stay Solid(Searched)
  117. 3VZFE Rear intake coolant tube
  118. 1987 4runner dash assembley & crazy temp gauge
  119. toyota frame
  120. Auto Trans Problem
  121. brake upgrade for 5 lug pickup
  122. 1990 toyota pickup transmission swap questions
  123. 3.0 2nd gen Auto Over heating
  124. windshield trim needed ASAP !
  125. 3vze Lifter problem
  126. 93' 3vze starting issues
  127. Sputtering if not warmed up!
  128. New 22RE swap. NO POWER!
  129. check engine light
  130. Fuel injector
  131. Idle question, maybe *something* needs cleaned
  132. 95 power steering conversion
  133. new engine parts
  134. opinions on heater
  135. What are these (part of 22RE)?
  136. Darn brakes
  137. 3.0 RPM too high?
  138. 3VZE Knock Sensor Problems
  139. EFI SWAP - Idle Like Crap
  140. 94 22re timing and afr question.
  141. 1994 toyota pickup 4x4 2.4 liter
  142. Power steering and fuel line threads...
  143. tie rod fell off
  144. sudden change in oil pressure 3vze
  145. Drivers side drum adjustment
  146. V6 Clutch in a 4Banger?
  147. 22RE for towing
  148. rear window motor for 86 runner
  149. Missfiring and high idle issue.
  150. New Owner of a 1995 4runner with transmission Question
  151. So, I'm THIS close to finishing up my V6 caliper swap and....(stuck)
  152. Converting my 95 4runner from auto to man.
  153. Headers for a 3vz
  154. Salt Water Fording Concerns
  155. 95 4runner fuel leak #2
  156. 95 4runner fuel leak
  157. Fuel pump/ Sending unit questions
  158. Engine fuse trouble!
  159. Ignition switch?
  160. umm.... advice needed...? spring mount and frame repair
  161. Emergency Knock Sensor Wire Question
  162. Noob Backspacing question and wheel choice
  163. Just Got My Truck
  164. test
  165. grill swap
  166. strange request
  167. 86 4runner running rough
  168. Injector service recommendation?
  169. crankcase pressure / idle question
  170. 1990 4runner 22re conveted carb'd: MSD and Stock Tach
  171. 22re fuel pump or maf issues?
  172. No Coil Spark 88 3.0 4runner
  173. 22re coolant leak /photo included.
  174. '86 4Runner: Tucker (Tuck)
  175. Vafm problem
  176. Viberation 93 4x4 v6
  177. Brand New To Me 86 4Runner and Intro
  178. 3VZE - Inspecting Distributor Question
  179. Hex bolt for manifold bolt - ok?
  180. Cooling system issues
  181. 2wd and 4wd radiator differences
  182. Overnight loss of spark in GM style ignition
  183. Transmission fluid capacity?
  184. What gear oil do you use for differential and transfer case?
  185. '94 4runner 4x4 3.0 front brake overhaul - HELP!!
  186. 1990 4runner 3.0 running rough, throttle hesitating
  187. $750 for valve adjustment; is that right?
  188. Idler arm replacement question (FA5040)
  189. 94 4runner tailgate removal help
  190. Would lint build tool but need your help
  191. First Gen 4Runner: Mirror Upgrade Options
  192. wiring harness
  193. 3.0 ZERO CLEARANCE valve measurement & adjustment (yes, I have searched)
  194. metal heater pipe to intake man gasket
  195. valve cover replacment tips please
  196. Clicking (not what you think) Fan Clutch?
  197. What is this tailgate part (clip for 1st gen 4runner)?
  198. 2nd Gen 4Runner in 1st Gen 4runner?
  199. rear axle bearing
  200. Anything I can do to save a 22RE on the cheap?
  201. tacoma rims on a 1993 2wd pickup
  202. well im back
  203. clutch fork options
  204. Have a stock height 87/88 4x4 you can measure ???
  205. running on 5 cyl. need info
  206. 1/2 door inserts no more rain
  207. 3vze Timing and Timing Belt Installation??
  208. Rough idle...Need HELP!!
  209. Roof Control Switch question
  210. oil pan gasket woes
  211. 22re turbo manifold
  212. Broken Bolt on Intake Plenum Help Please
  213. Need parts number for cold start injector fuel line
  214. Need part number for vent tube on valve cover
  215. Mystery Starting Problem
  216. Mystery miss/hesitation
  217. Cold start issue!!!!
  218. 2nd Gen 4Runner Ball Joint Replacement write up!
  219. MPG on a trip
  220. 1988 specific VSV vacuum & electrical routing
  221. 88 4runner engine swap
  222. Exhaust crossover pipe
  223. 22r carb, no start!
  224. IFS 7.5" front differential disassembly
  225. My new 86 4runner
  226. Another idle problem
  227. Mystery Bracket?
  228. 4runner moving rear bench seat back a few inches
  229. 86 22 rtec turbo question
  230. oil ports head, lifters & valves
  231. how do I id gear ratio
  232. 22re does not want to rev.
  233. code 42-broken speedo cable
  234. 89 sr5 3.0 idle problems
  235. automatic transmission
  236. Can I replace my fuel pump w/o dropping the tank?
  237. Getting the exhaust manifold off.
  238. head gasket question.
  239. Your thoughts 5VZ-FE Vs. 1UZ-FE
  240. 95 4runner Factory Security horn beep
  241. 22R Vacuum Advance
  242. Misfire need some help checked everything I could think of...
  243. 93 22re problems........HELP.
  244. 94 22RE cracked block--OK to use?
  245. intermittent misfire
  246. 3.0 3vze Pulling Plenum for Fuel Press. Damper - what else should I do?
  247. EFI Relay?
  248. 3.0 dead cylinder
  249. HELP!!!!! Truck Pulling to the passenger side
  250. Ultimate 2wd Rear axle upgrade using all factory Toyota parts!!
