$750 for valve adjustment; is that right?
Old Nov 1, 2012 | 04:01 PM
adamthedroog's Avatar
I just called Toyota and asked how much it would be to get my valves adjusted on my 3.0 and he said it'd take five hours and it costs $750 dollars. Does that sound about right?
Old Nov 1, 2012 | 04:07 PM
250000_yota's Avatar
On a 3.0? Yup. Gotta pull the plenum, then check where the valves are adjusted, then match up the new shims. Rather time consuming.
Old Nov 1, 2012 | 04:10 PM
*sigh* ugh. Well that's disappointing. Thank you for the response.
Old Nov 1, 2012 | 04:25 PM
Sorry to give ya the bad news. I work for a Toyota dealer. At my shop rate, labor would be $500 alone, plus the plenum and valve cove gaskets, then, if you did need replacement shims, it all adds up pretty quick, not to mention what the tech finds and recommends while he's got your truck in the bay. Personally, I'd check the valve clearance yourself. If any aren't within spec, then consider getting it done. Besides, it's a 3.0 V6. Chances are the valve cover gaskets are leaking
Blamalam
Mar 12, 2022 07:34 AM
Jason Webber
Sep 2, 2015 03:30 AM
DukeOfHazard
Aug 16, 2015 01:48 PM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
