Tranny questions
Old Nov 15, 2012 | 03:38 PM
7mg4me's Avatar
Tranny questions
So I need to rebuild my transmission due to the main bearing going out. I bought it used because my last one just crapped out on me. I plan on rebuilding it. Does anybody know if i can "mis-match" gears in the tranny? I want to make 1-3 for crawling and then 4&5 for highway speeds. does anybody know if this is possible? I have never taken apart a trans, but i figure it shouldn't be all that complicated, especially with the handy dandy internet.
Old Nov 17, 2012 | 05:36 AM
MudHippy's Avatar
It's possible...in theory(in fact it's been done before to some extent, by Toyota transmission specialists). But it's probably a lot more complicated than, and therefore may not be as feasible as, you might imagine it would be.
Old Nov 17, 2012 | 08:20 AM
scope103's Avatar
Before you conclude it "shouldn't be all that complicated," you might want to browse the manual. http://personal.utulsa.edu/~nathan-b...nualtrans.html Lots of SSTs called out, and some places where you have to select the correct-size shim/part to set axial play.
But I don't think Toyota would publish it in the manual if it was impossible to reassemble your own transmission, so give it a go. Do take lots of pictures for us in the peanut gallery.
Old Nov 18, 2012 | 04:52 PM
TrikeKid's Avatar
Most of the SST's are just going to be pullers etc... Manual transmissions are "easy" to rebuild to me but then again I'm a tech in a transmission shop. You will need a shop press and a set of bearing splitters, a good pin punch set, along with the usual solid set of mechanic tools. I wouldn't want to do it without access to at least a solvent tank, preferably a heated parts washer to clean everything.
I don't think you'll find different enough gear ratios within a transmission family to make any sort of swapping worth while.
Dieselmann
Feb 19, 2019 02:57 AM
Tonetrk
Aug 6, 2015 10:06 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
