Ball joint spacer problem*
Old Nov 15, 2012 | 07:30 AM
Vote4Runner88's Avatar
Just installed the ball joint spacers and now my driver side inner tie rod rubs on the frame... What gives? Any ideas would be greatly appreciated, want to get my rig back on the road!
Old Nov 15, 2012 | 07:37 AM
lofreqjeff's Avatar
That sounds weird to me - I've had BJ spacers on my truck for 5+ years and never had any issues. Any chance you can put up some pics - Pics always help.
Old Nov 15, 2012 | 10:49 AM
junkyardog05's Avatar
After putting on the spacers have you had lined back up? that could be your problem
Old Nov 18, 2012 | 07:04 PM
Old Nov 18, 2012 | 07:06 PM
This is the drivers side* when I turn left the back of the tie rod rubs the frame... I have not been able to drive it anywhere to get it aligned yet due to the inability to make left turns (suppose if I planned it out just right I could get away with all right turns there) lol!
Old Nov 18, 2012 | 07:41 PM
Zpd426's Avatar
somethings bent
Old Nov 18, 2012 | 07:51 PM
mightymouse's Avatar
back up take another pic.
Old Nov 19, 2012 | 07:19 AM
Old Nov 19, 2012 | 10:50 AM
ZUK's Avatar
ZUK
Rotate that tie rod into the correct orientation and then tighten those 2 loose bolts and problem fixed.
Old Nov 19, 2012 | 10:58 AM
westjohns yota's Avatar
it needs to be on the outside of the linkage rod.....
Old Nov 19, 2012 | 11:26 AM
lofreqjeff's Avatar
Thats what I was thinking too now that I see pics - tightening those bolts should push the rod forward enough to fix the clearance issue.
I'm not sure about that - My 89 4Runner's tie rods are on the inside like shown in the pic. That doesn't mean its right, but thats how mine have been for the 9 years I've had the truck and never had any issues or had anyone tell me they were wrong.
Old Nov 19, 2012 | 11:29 AM
It will not go on the outside of the centerlink, the hole is flared to fit the tierod post and to be compressed in, and which bolts are u refering to? I put it back on the way it was taken off*
Old Nov 19, 2012 | 11:30 AM
Old Nov 19, 2012 | 11:32 AM
Well I took a closer look at the old tie rod and it is def. showing damage due to rubbing so I'm going with ZPD, something is bent...
Old Nov 19, 2012 | 11:36 AM
I cranked everything down tight and relaxed the torsion bars a little and I'm able to drive it with minimal rubbing so I think I will go see what the alignment guy can do for me... It almost seems that the angle the tie rods are at now due to the spacers has moved them out of that "sweet spot" in the frame where they were ment to originally function. The frame sort of recesses in to allow clearance at a normal angle.
Old Nov 21, 2012 | 12:10 PM
Something has to be bent, could be your drag link being bent some by bumping into something while out on a trail. I have those spacers on my 87 truck and they do great.
Old Nov 21, 2012 | 03:49 PM
ZUK's Avatar
ZUK
Hey Vote--
Can you shoot us another updated pic of the rubbing with everything tightened up?
Old Nov 21, 2012 | 04:56 PM
Jay351's Avatar
check your idler arm and pitman arm. Had a similar issue when my idler was worn out, allowed extra movement.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
