22re...no oil in the Oil filter?
Old 11-11-2012, 06:40 AM
ricoace's Avatar
1994 pickup 4x4 2.4 liter.
Hi Everybody
I have a question that I should know the answer too, but I am questioning myself reluctantly. Just had my 22 re rebuilt ( Engine shop here in Houston)...yesterday as I was changing the oil, Removed the oil filter and its dry!...there is no oil in this filter...wth? ....ive never changed a oil filter in a vehicle where the dang thing is dry and not pouring out when you remove it... so this morning just out of curiosity, I take the filter out ...with oil in the oil pan..of course...the filter is dry...no oil. CAN Anybody tell me what in the hell is going on? ....lol...
Old 11-11-2012, 06:47 AM
ricoace's Avatar
The Engine isn't over heating, but I have noticed it warms up faster than ...the "old" engine did. Also, the needle never fluctuates or moves with for example changes in temperature...where before it used too. Put over 600 miles on this engine since the rebuild.
Old 11-11-2012, 07:12 AM
matstaley's Avatar
pull the valve cover and see if there is any oil on top of the heads. If not you probably don't have any oil pressure. Replace the oil pump if this is the case.
Old 11-11-2012, 07:20 AM
ricoace's Avatar
Thanks Matstaley
And that is def on my list to do...but I am showing oil pressure on my gage?...What does that mean?
Old 11-11-2012, 07:45 AM
superex87's Avatar
whats happening is the oil is draining back into the oil pan. This is not really a good thing but its not terrible either.
Didi you run the engine before you changed the oil?
What brand oil filter?
Some oil filters have a anti-drain back valve in them to prevent dry starts.
matstaley's Avatar
possibly a plugged oil passage. run a can of seafoam in your oil and see if that cleans it up.
Old 11-11-2012, 08:46 AM
blknblubkrdude's Avatar
If no oil was going through your filter, your engine would be siezed.
Like said above, you either have a oil filter with a bad anti-drainback valve, or a filter that doesn't have one.
Go to Walmart and pick up a new one!
Old 11-12-2012, 12:41 AM
wyoming9's Avatar
Red face
Do you mean the oil filter was completely dry???
Or it just was not full??
Make sure you get a filter with aantidrain back valve.
Yes if you drove 600 miles and your engine did not explode I would think it is your filter.
Old 11-12-2012, 04:02 AM
Swimmerboy2112's Avatar
This happened to me once with a Fram filter. Ever since then i've used Toyota OEM filters and have never had this happen.
Old 11-16-2012, 01:19 PM
kornhuskerwizard's Avatar
when i had my 88 truck rebuild done, i had the machine shop do the bottom end and i did the rest. put it all together ... no oil pressure. come to find out theres a allenhead plug by one of the main caps in the pan. didnt get put back in. hope thats not your case.
Old 11-16-2012, 01:48 PM
Sturmcrow's Avatar
This was my question too. Did the filter look brand new on the inside, or was it just not gushing oil when you removed it?
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: 22re...no oil in the Oil filter?
