Blazeland long travel track width
Old Nov 8, 2012 | 03:33 PM
anthony14's Avatar
Does anyone know how much the track width increases on the Blazeland kit?
Like for example the Total Chaos kit increases the width by 6.5 inches overall.
I'm looking to see what the best Kit would be to pair up with a Drop Bracket kit with coil overs and 35x12.5's.
Old Nov 8, 2012 | 04:49 PM
donomite49's Avatar
think they are the same, they both use T100 axles, don't they?
https://www.yotatech.com/forums/f31/...d-lift-249606/
nate is a member on YT you can pm or e-mail him.
you checked his website?
Old Nov 8, 2012 | 05:07 PM
anthony14's Avatar
I have checked the website just didn't see anything about the Track width increase. im wanting to do like nate did on his 4 runner with the long travel and drop bracket on 35's.
Old Nov 8, 2012 | 05:12 PM
NautiRedneck's Avatar
Im interested in this as well. Wanting to do the same thing, not sure how much of a drop bracket to use though... or how long the coilovers should be...
Old Nov 8, 2012 | 05:39 PM
anthony14's Avatar
https://www.yotatech.com/forums/f199...thread-203458/
That's the build Ive been focusing a lot of my attention on. This truck will most likely act as my DD as well so i like how Nate found some wheels with the deeper backspace to help manage the width.
Old Nov 8, 2012 | 05:43 PM
Numbchux's Avatar
The width difference between BL and TC is negligible at best. The fact that they use the same axles is a dead giveaway.
Old Nov 8, 2012 | 05:50 PM
anthony14's Avatar
Just curious. It looked pretty wide from the write up in my 4wd Toyota owner mag when the did the grudge match. They noted the IFS 4runner was 8 inches wider than the solid axle.
Old Nov 8, 2012 | 07:41 PM
donomite49's Avatar
they make fiberglass fenders/bedsides for the extra width.
i like this as a guidline, except for my older truck.
https://www.yotatech.com/forums/f201...merica-257093/
Old Nov 8, 2012 | 07:53 PM
anthony14's Avatar
Im just not a huge fan of the fiberglass. Kinda bothers me, not sure why.
Old Nov 8, 2012 | 08:28 PM
donomite49's Avatar
i've ridden in a long travel 2nd gen pu, and believe me you won't worry about the glass.
unforgetable. lol...
thing is if you break it glass is easy to repair, tear it up too many times just replace it.
http://www.hannemannfiberglass.com/
Old Nov 8, 2012 | 08:46 PM
anthony14's Avatar
I think its more the huge flared out look that bothers me. I live in Tennessee so that's not something you see everyday out here.
Old Nov 23, 2012 | 10:33 PM
BlazeN8's Avatar
Blazeland is about 3.5" wider per side. Yes the T-100 CV axles are the dead give away. Having a standard part available is necessary as building a custom CV assembly would be expensive. T-100 CVs are easily obtainable and cost can be as low as $65 each.
A live axle from say a 1985 or older truck or 4 Runner is 3" narrower than the 1986-1995 IFS in standard form. If you have a LT kit that is 7" wider than stock IFS.... then yes it will be about 9" wider than an old school live axle.
A live axle rig needs a super shallow backspace rim to run a 33x12.50 or bigger tire. Even with 15x8 with a 3" backspace the tire will rub the frame and front leaf spring. I like adding 1.5" wheel adaptors on my 1985 P/U just so nothing rubs.
On LT IFS if you run a 15x7 or 15x8 rim with a 4" or greater backspace the track width is more acceptable. Mud flaps or fiberglass may be required by law.
jashoeuh
Nov 18, 2024 08:08 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
terminator
Jul 27, 2015 07:13 PM
KyleT
Jul 21, 2015 07:54 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
