how do I id gear ratio
Old Oct 27, 2012 | 12:18 PM
skinny's Avatar
ok m 94 runner 3.0 auto has started to make bearing noise in the rear
i may have located a complete rear end for cheap so I may change it out
I need to find the ratio of the gears can this be done by vin or is there supose to be a tag on diff
Old Oct 27, 2012 | 12:20 PM
BigBluePile's Avatar
By vin
4x4wire.com
Old Oct 27, 2012 | 01:01 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
http://www.off-road.com/trucks-4x4/t...ion-18588.html
this will help you to figure out your ratio using the A/TR code found on the ID plate on the inside of the driver's door jam.
Old Oct 29, 2012 | 02:07 AM
skinny's Avatar
Here is my vin
JT4VN36H9R0018788
Old Oct 29, 2012 | 06:48 AM
MudHippy's Avatar
It's not part of the VIN. With that VIN you could have one of many different gear ratios. You need to find the axle code.
Old Oct 29, 2012 | 09:41 AM
skinny's Avatar
Ok since I think I really only need a right axle I see in some used parts they want to know if it was 2 or 4 wheel abs Is there something on axel different Or as long as it is a abs axle
Old Oct 29, 2012 | 03:42 PM
MudHippy's Avatar
It needs to be from a vehicle with the same axle code(and ABS if that's what you have). Or from another 4WD truck or 4Runner with the same gear ratio(and ABS if that's what you have). 2 or 4 wheel ABS has nothing to do with it, because it's a rear axle(since if you have 2 or 4 wheel ABS, the rear axle has ABS either way, that's why it's not even called 2 wheel ABS, it's called rear wheel ABS, or 4 wheel ABS if the front has ABS too).
Old Oct 30, 2012 | 03:04 PM
skinny's Avatar
are the left and right axles the same
or do I need to make sure I get the right or left
Old Oct 30, 2012 | 05:42 PM
rattlewagon's Avatar
Your talking about the cvs. No gear ratio involved.
Old Oct 30, 2012 | 05:48 PM
skinny's Avatar
no i'm messing in the rear not the front
Old Oct 31, 2012 | 05:12 AM
waskillywabbit's Avatar
http://home.4x4wire.com/erik/diffs/
:wabbit2:
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
