Code 51 & 21 on Check Engine Light
Old Nov 12, 2012 | 02:17 PM
Evrgrnmtnman's Avatar
I have a 88 TP with 22RE, 5spd. The check engine light goes on and off as I'm driving it. Checked the codes and got the 21 & 51, I have recently put a brand new O2 sensor on, so don't understand why I would be getting a O2 code?? Any help resolving these codes would be appreciated....
Old Nov 12, 2012 | 02:55 PM
87redtruck's Avatar
Is your truck running rough? Are there any symptoms of rough idling/poor gas mileage?
Try removing fuse for computer for half hour. That may reset it.
Also, try replacing your TPS or coolant temp sensor (located under thermostat housing with green housing). Two jobs that are not too difficult or costly to do.
Old Nov 12, 2012 | 03:18 PM
combatcarl's Avatar
What brand of O2 sensor? Sometimes the Bosch or others don't tend to work as well as denso or Japan brands.
'89 22RE 4x4 longbed DLX
Sent from my LG-P505 using YotaTech
Old Nov 13, 2012 | 07:17 AM
Truck runs normal, don't see any difference in driving it, except the light bugs me
Old Nov 13, 2012 | 07:21 AM
What fuse are referrring too??
Old Nov 13, 2012 | 08:43 AM
87redtruck's Avatar
Driver's side fuse box. (Located inside the truck, behind the plastic shroud, next to your left foot.)
Remove the "EFI" and "Engine" fuses for about a half an hour then reinstall them. Should do the trick to reset the CEL.
Old Nov 18, 2012 | 07:29 AM
Turns out it is a Bosch that I just recently bought.....Any remedies except for replacing it with another brand?
Old Nov 18, 2012 | 07:33 AM
TNRabbit's Avatar
Replace with NTK or DENSO.
Old Nov 18, 2012 | 07:48 AM
scope103's Avatar
Code 21 is for the O2 sensor heater circuit, not the sensor itself. I'm not a big adherent to the "Bosch is no good" school, but I don't think it applies to the heater side anyway.
Do pull the EFI fuse for 30 seconds (http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf) to clear up the code 51. Since the code 21 is sensing an open or short in the heater circuit, I'd start with pulling the connector apart and reseating it just in case the connector is open. If that didn't do it, I'd use a multimeter to check for a short/open in that circuit.
You can spend a lot of money on O2 sensors swapping them blindly.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
