1993 4runner grill on a 1990 4runner
Old Nov 14, 2012 | 01:27 PM
thezrutherford's Avatar
Hey i hate the way the 90 and 91 grill looks and was wondering if i could put a grill from a 93-95 4runner on it?
Old Nov 19, 2012 | 02:17 PM
Some one reply please
Old Nov 19, 2012 | 05:52 PM
Roofmaster's Avatar
Yes you can.
I I put a grille from my 86 4x4 on my 95 4x4.Take the grill assembly off then remove the headlight parking light assembly off each side leaving just the center grill to put away somewhere in case you change your mind.Next step is to take the replacement center grill section and attach the parking light headlight assembly from your truck to it.It should be plug and play interchangable but you may have to do some modifying and fabrication to get it to fit properly.I had to.But its only plastic and with a little imagination,a solderig iron for melting pieces and a sharp utiliy knife for trimming and you can do wonders.Because its plastic its good practice for fabrication.When its time to reattach the grill your stock parking light headlight assembly will screw back into place but you may have to trim away the clip atta hments that dont line up correctly with your trucks clips then you can use zip ties in place of those areas.Anything can be done with patiemce,persaverance and imagination.Good luck.
Old Nov 19, 2012 | 06:59 PM
brianh699's Avatar
You can probably do it but the later 2nd gen 4runners had different headlights and probably different marker lights too. You'd half to change out everything, bumper may be different as well.
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
