RV and Pickup 22RE differences?
Old Nov 13, 2012 | 07:13 AM
YoYoMa's Avatar
Are there any differences between the RV 22RE and the one that they put in pickups other than the exhaust manifold and cam?
Specifically are the valve sizes on the RV head larger than the pickup counterpart?
Are there any other differences?
Old Nov 13, 2012 | 02:44 PM
MudHippy's Avatar
There are no differences of any kind...period. Why would there be?
Maybe because there's no such thing as "the RV 22R-E"
Old Nov 13, 2012 | 09:51 PM
abecedarian's Avatar
Even though there have been 22RE based RV's (anyone claiming to know anything about Toyota trucks should know about the Dolphin and others), and U-Haul trucks (though they tended to be the 88+ V6 type), and 22RE based 1 ton and others....
... under the hood, it's still a 22re.
There could be differences in the rear end, if it's a dually for instance, and possibly the transmission, but other than that there's no difference engine-wise.
Old Nov 13, 2012 | 09:55 PM
Anyone claiming there wasn't a 22re RV should their self.
Old Nov 14, 2012 | 04:06 AM
YoYoMa's Avatar
I had seen on engnbldr's that the RV head he sells has O/S valves and was not sure if that was a RV thing or something he does to his heads.
Who makes a good flowing reasonably priced head other than LCE or engnbldr?
Any real good machinists you would recommend for a rebuild, port and polish on the current head and intake?
Old Nov 14, 2012 | 08:24 AM
YoYoMa's Avatar
So, the cam is the same as the pickup too?
Old Nov 14, 2012 | 03:29 PM
MudHippy's Avatar
Yes. The term RV cam refers to a type of camshaft grind. Not necessarily the vehicle it's installed in. You can put an RV cam in any vehicle. And just because it's an RV doesn't mean it has an RV cam. RV cams are best suited for one though, since it's harder to get a heavier vehicle moving. And they assist in that by providing more low end power/torque.
Race Camshaft, Street Cam, RV Camshaft: What is the Difference?
In a nutshell:
RV cam = better low rpm torque
Street cam = better middle rpm torque
Race cam = better high rpm torque
Old Nov 16, 2012 | 07:54 PM
YoYoMa's Avatar
Thanks.
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
msane99
Jul 11, 2015 08:08 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
HRDC0R19
Jul 5, 2015 06:43 PM
