code 42-broken speedo cable
Old Oct 26, 2012 | 04:51 PM
dzldust's Avatar
Code 42-stumble
1988 V6 3VZE 4runner
I bought the 4runner not running,ended up being cracked heads,so I rebuilt motor ,got it all back in and once got her running I decided it was time for a drive.
Truck had a hesitation /power loss that felt like a distributer with moisture inside.I have checked codes and all I have is a "CEL 42",Everything is plugged back in but the only thing that does not work is the speedo,Its broken at the t-case end.
would this cause the stumble/power loss?I have always had 22r/22re toys and have never run into this problem,did a pretty decent search and never came up with anything cut and dry as a reason for this particular problem.
Old Oct 26, 2012 | 05:00 PM
brianh699's Avatar
I have unhooked my speedo, and get code 42. I have an 89 4runner 3vze, but I have no power loss. Just check engine light. I think your problem lies elsewhere.
Old Oct 27, 2012 | 10:36 AM
dzldust's Avatar
I think so as we'll,I have the stumble at idle and throughout rpm range,no fuel odor at exhaust,I wish I could test the injectors under the plenum,I hear the ones on the drivers side clicking.
Old Oct 28, 2012 | 10:13 AM
dzldust's Avatar
Got speedo ordered
Dieselmann
Feb 19, 2019 02:57 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
moparbay
Sep 3, 2015 12:48 PM
JustToynAround
Aug 19, 2015 11:46 AM
