Throttle body cleaned.
Old Nov 10, 2012 | 05:39 PM
BStrick1993's Avatar
So cleaning the throttle body and intake plenum worked out pretty well. Pulled a lot of carbon out and it is running great.
Old Nov 10, 2012 | 05:43 PM
rworegon's Avatar
Yucky! Nice cleaning job. You truck will appreciate the TLC.
Old Nov 10, 2012 | 06:04 PM
Thanks, It was running a little rough around 3000 rpms, losing power a little bit. So, I figured I'd give it a good cleaning and see if that works.
Old Nov 10, 2012 | 08:50 PM
Little Elger's Avatar
Stupid egr's there is no reason for carbon for carbon to be there.
Old Nov 10, 2012 | 11:21 PM
Terrys87's Avatar
Here is how I solved my carbon problem and no error codes. Have done it on several trucks. I just grind the edge down with a soda can or something similar. Can be removed for inspections.
Copied...
I take a thin piece of metal and bolt it to the EGR and grind it to fit to shape. After all of the carbon that builds up in these and how bad it plugs up all of the tubing. I just dont see how this can be good for the motor. I have spent alot of time trying to get carbon out of the Plenum and still have a ways to go. I can always remove it for inspections, if we ever have to start having them.
Old Nov 11, 2012 | 03:49 AM
waskillywabbit's Avatar
I just cut off the flanges, weld up the hole and take the EGR pipe off altogether.
:wabbit2:
Old Nov 11, 2012 | 06:47 AM
I just haven't had time to do this yet.
Old Nov 11, 2012 | 02:25 PM
Took it for a spin today to make sure that it was running good. The only problem is I think my throttle cable has a little too much free play. Other than that I am really glad I cleaned this out.
Old Nov 11, 2012 | 02:48 PM
Terrys87's Avatar
Great job. It has to be running a little easier. What has you thinking that the cable has to much play?
Old Nov 11, 2012 | 03:10 PM
It drops to near nothing for a second after a good pull through the rpm range.
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
