Air conditioning question
Old Nov 18, 2012 | 11:44 AM
fletcher0780's Avatar
I have a 92 dlx pickup 4x4 with a 22re and aut trans. My truck did not come with AC from the factory, but I have access to a complete AC system from an 87 4runner 4cyl. What will and will not work for this swap? I don't want to buy everything if most of it is different.
Old Nov 19, 2012 | 01:05 AM
Any ideas on this? Did toyota change the AC system between an 87 4runner and 92 pickup?
Old Nov 20, 2012 | 04:35 AM
JayKray's Avatar
I recently found out that there are at least 2 different bolt patterns for the compressor/engine mounting. It's only the top rear bolt, but it is different.
Sorry that I can't be of more help.
Old Nov 20, 2012 | 06:58 AM
Marc's Avatar
You could go to ackits.com and see which parts are different.
Old Nov 20, 2012 | 07:21 AM
technojunkie's Avatar
I can tell you that at minimum, the amplifier and dash switch are different. If you can read electrical diagrams and are able to trace simple circuits you can re-wire the harness that connects the amplifier/evaporator assembly to the vehicle.
I installed a factory A/C kit from an '86 into my 93. Everything fit except those 2 parts.
Old Nov 20, 2012 | 10:08 AM
smracing's Avatar
Wide pattern is the R12, narrow is r22.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
terminator
Jul 27, 2015 07:13 PM
Avenged
Jul 9, 2015 07:55 AM
