- 4runner engine swap
- EFI fuel problems
- OBA Questions
- california emissions 1994 4runner
- add a leaf
- 1993 4Runner A/C Problems
- pinion seal still leaking ..whats next
- 91 4Runner sunroof install how-to
- front end
- 22RE Coolant hose identification
- 22re coolant "pipe" question
- 22R swap...Need a shop to re-tune
- Replaced oxygen sensor, now it idles horribly.
- 92 3vze rough cold idle :(
- Piston Ring position
- Seats Sag Inward (87 4runner)
- Looking for a person/place to rebuild 2wd A/T 1991
- Recomended 3.0 head gasket?
- 84-85 vs 86-88 ride height
- B&G Fiberglass now have 89-95 beds!
- v-8 4Runner opinion
- 22RE idle issue
- Tranny Question
- Louder valve chatter/ping when warm
- late 80's vs early 90's frame need help
- A/C Wiring connection cable; HOWTO?
- Lowering Compression
- Need help with routing of Starter Relay Wiring on a 22re truck...
- shift problems.
- stock vs. LCE Valve Cover
- how do i repair door pannels..
- 22R fuel system upgrade
- Is my clutch toast due to rear main leak?
- intermittent missing 22re under load
- Aisan Carb Stumbles
- 1986 2wd pickup drive train questions?
- Overheated axle shaft?
- Time for paint!
- Head bolt re-torque
- 86 22ret wont stay running. please help!
- Manual Hub issue?
- 1995 IFS rebuild
- I need a pic of the bottom of a 22re intake manifold
- how do you test an ignition switch 94 pickup 22re
- truck wont start after water pump change
- check engine light - random
- Apparently I have 3 TDCs on my V6....
- Oily/Greasy substance from tailpipe
- body shop estimate
- front main oil seal
- front differential clicking
- cores and longblock 22res
- Shifter boot advice.
- How long for a head gasket job 3vz
- Rebuild hilux 1989 22re all photo needed
- gm 1 wire alternator installed on 1988 22re
- 1990 toyota pickup cant get to stay in 4low.
- Newest project. Exo!
- Cam Shaft Questions
- Timing chain problem!!!!!
- water/coolant leak coming from the back of motor?
- Replaced spark plugs in 3vze, now running like ass, thoughts?
- I need tips for installing Rear Shocks..... Very Cramped!
- Fuel pump circuit
- Possible Head Gasket replacment project gone wrong?
- Rear drive shaft
- Oil selection for high temps
- 1990 22re wiper linkage bushing
- Spare tire carrier
- LSD in a 93 pu? How to go about
- can a 22re/5 speed tow 5000 lbs?
- Rebuilding my 4 Speed
- Clutch won't bleed
- clutch chatter with no slippage and transmission mount
- 1994 Pick up DX Carpet
- 22r carb issues
- AC Retrofit Question
- electrical problem.. alt maybe?
- 92 Toyota Pickup
- 1st Gen 4Runner Style Mirrors
- 95 4runner wont start when hot!!! help....
- Starter problem?
- 3.0L engine issue No Spark
- 94 3.0 overheating?
- help with rough running 3.0
- Rebuilt engine with only 200 miles...ready for a trip?
- Ok...Upper control arm HELP.........
- 2nd Gen 4runner Rear Diff Extension
- Help? Name this part on Intake manifold
- w56a vs w56b t-case
- Shifters are binding
- Need Tech Help....Rear Axle U-Bolts Installation PICS
- Vacuum leak 1995 4runner 3.0 V6
- aftermarket UCA's and poly bushings... ARGHH!!
- What front bumper/light bar is this?
- A340H problems and rebuilding questions
- New Alternator
- Back Glass
- sway-a-way 1633???
- 4:88 front diff swap
- what is code 41?
- Comparison of 22RE vs. 30. V6 Release Bearing for my 1988 4Runner W/ Detailed Pics
- '92 4Runner v6 not turning over
- $600 Toyota 4runner for my son.
- more quech and deck height questions
- Manual Hubs Installed But CVs Still Move.
- my new rig
- Suprisingly Slow Warm-up
- Motor struggling once warmed up after top end rebuild
- Ignition Issues
- 86 4runner bogs & stinks between2800&3000
- knock sensor
- Vacuum line from Canister
- '89 4Runner - A/C Amplifier & Electrical Issues?
- Apparently hard to find parts
- 22re stalling/restarting while driving???
- 3rd gen interior in a 2nd gen 4runner
- vibration from the driveshaft..whats next???
- Why is my rebuilt 3.0 overheating?
- 3VZE Bogging badly?
- Timing chain
- A cooler Spark Plug?
- 1994 4runner 3vez starting problem
- window motor not working
- Power kicks in but lacks down low
- '88 4run - 2" or 3" body lift?
- 22re unreal amount of power
- Parts needed for a brake job.
- Custom wooden and flat beds
- Do I have to take the tank out for replacing fuel pump in 90 truck?
- Fuel Pump Compatibility
- solenoid compatibility
- oem roof racks
- Need Help Splicing Wiring Harness Back Together
- Motor swap... more like a re-birth!
- Battery platform & body part sources?
- Coolant temp wackiness
- Need some advice on my options
- Preventive Maintenance... Starting Issues
- Smoky exhaust with a little clear liquid and sometimes black spots at startup?
- Diagnose THIS!
- hot trans.
- Diff vent broke - now it leaks 75w90
- Extended steering shaft. NO Cutting or Welding Required
- Help! Whirring noise from back of 4runner: Pinion bearing?
- Reassembly trouble after head gasket replaced
- quietest exhaust for 22re
- starter problems
- Air in my fuel lines
- Bad Converter?
- Cab Mount Measurement Request
- Flat cam lobes
- Antifreeze leaking
- Finally Found A Mint 2nd Gen!!!
- 3vz Squealing Belt Issue
- Exhaust farting ( misfiring )22re help
- Shifter assebly
- 22re Oil pump bolts
- More power with O2 sensor disconnected?
- turbo burning antifreeze?
- plastigage 22r rod bearings with spare bearing?
- Front end knock/clunk
- 94 pickup 2wd spring over axle?
- '95 4Runner VERY stiff steering after a few minutes of driving (no leaks to be found)
- Insulating cab with undercoating
- Unusual idle behavior
- time chain already beenc changed?
- 3VZE bad rings?
- w56 rebuild thread
- What do you think is compatible with my 87 4runner from a 66' CJ5?
- SR5 wheels with BJ spacers?
- I'm having a brake booster issue
- 1990 4Runner - chugging, missing
- New truck Tranny problems
- 22re Headgasket lifespan
- wierd 4 wheel problems
- I'm having a timing issue
- how do you replace front cam seals?
- I got nothin'!! 22re wont start after top end rebuild
- 2wd p/u on 31's??
- 93 v6 manual pickup no fuel/spark
- Random clunk and pulling- 2nd gen runner
- I need any suggestions before my first enginge start since I installed new parts.
- Replacing the 3VZE Fuel Filter (w/pictures)
- rear main seal replacement
- Coolant leaking into intake through the IACV (pics!)
- RPM indication jumps around
- V6 Auto guys, does your shifter jump around?
- metric oil pressure fitting
- Weber 32/36 high altitude questions
- 2WD Lift Spindles
- Changes form 88' to 89'
- R151 Trans/22re, which clutch?
- I bought an 87 22R 4WD. What next?
- 1990 22re manual trans oil leak at driveline?
- Any 22re "Specialists" in Los Angles?
- Removal of Rear Windshield
- '86 Turbo truck cracked manifold
- Sealing a header
- Camber issue - need input
- drivers side rattles like crazy going over rough terrain
- 86 22RE injector o-rings leak after installing them twice.
- no crank, cranks without key
- Differences in Driveshafts
- 87 4runner 22re Temp Gauge fix, finally!
- Valve Lash/Shim Adjustment HELP?! Video included
- 92 4runner headlights won't work
- 1992 4Runner 3.0 Fuel Line issue...
- Water pump is toast... wondering about HG's
- help. need indy mech in east lansing mi - FUEL LEAK
- truck turned 4runner
- 4x4 pu self front end align?
- Distributor/Idle problem, please help!
- Arb bull bar installed-pics
- Just purchased '92 4Runner
- rear U-bolts question
- Is this exhaust or a misfire? (Video)
- engine wont rev, surging
- AFM and Battery Swap, Wiring Question.
- $65 home brew bumper
- 92 4x4 truck swaying issues
- LIFESPAN of rebuilt 22-re?
- Transmission- What is this?
- Heim Joints for Tie Rod Ends
- No compression 94 22re help!
- key problems
- bushwacker cutout flares question
- Engine no start
- Pilot bearing install
- 4.56's.......Worth it?
- Console lid question
- Died While Running, No Start
- 1st Gen 4Runner vs FJ80
- Restoration parts?
- Thermostat question
- Clutch & Brake Pedals Freeze Simultaneously
- 22RE Valve Stem Seal Replacement
- auto trans noise
- Another 22RE to listen to (vid inside)
- 4:88`s
- first Gear won't engagr
- 1st gen 4runner Amber dash bulb swap (with pics) - $10 mod!
- Marvel mystery oil for unseizing engine?
- Removing Spare tire carrier
- 94 22re wont start.
- Ground Strap
- 22re replacment
- Remounting sleeping deck
- Fuel Line Replacement
