hot trans.
Old Aug 30, 2010 | 08:13 AM
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
hot trans.
does / did anyone have a problem with their transmission getting hot . mine is starting to do that. you can feel the heat coming through the center console around the shifter. anyone know anything about this problem
Old Aug 30, 2010 | 08:40 AM
Keith B.'s Avatar
Did you put 3" larger tires on a auto trans 4R without regearing the axles? Then I'd say you can expect to cook that trans faster than with the stock tires and gearing.
Old Aug 30, 2010 | 11:01 AM
crawyota's Avatar
no, didn't need to regear , mine came stock with 4.88's in it from the fact. this just started , i have had bigger tires on it for 3 years now.
Old Aug 30, 2010 | 06:13 PM
wiseguymmiv's Avatar
Mine used to overheat when cruise control was used in hilly interstate terrain, or when pulling even the lightest of loads. The heat was palpable through the floor, and the Trans light would come on when it really got hot. Several years ago I installed a Hayden tranny cooler behind the radiator, and have never again had that problem.
Old Aug 30, 2010 | 07:12 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Sorry, but that logic is wrong.
Old Aug 31, 2010 | 02:54 AM
crawyota's Avatar
well I have read on different forums, including this one , that some of the 2nd gen 4runners , have come with 4.88 gears as opposed to the I think 4.10's that i believe they normaly came with. which i could see regearing, but the 4.88's are enough for up to 33" tires. I am just going by what I read. but like I said I 've been running large tires fo a while now , and my problem just started .
beebeeri000
Oct 2, 2015 10:42 PM
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
Odin
Sep 26, 2015 06:56 PM
taraf
Sep 25, 2015 02:57 PM
