22r carb issues
Old Sep 3, 2010 | 10:41 AM
Mr. Maynard's Avatar
22r carb issues
Got a stock (Aisian) carb on a 22R motor, which I just replaced. (Carb is originally from the previous motor which blew.)
I've played with every screw and choke setting on the thing I could find, and it still won't idle. The p/o had a Weber setup on it and plugged up a whole mess of vacuum lines which I am currently trying to figure out what goes where, and it's driving me nuts. I have a shop diagram of the stock vacuum lines but I can't make heads or tails of it.
A mechanic pal of mine told me he's pretty sure it's a vacuum leak somewhere and suggested that I just plug up and/or remove EVERYTHING except the dist. advance lines and the hose for the brake booster. I live in an area where there's no emissions or smog testing, so that's not an issue.
Does anyone know what ports or lines exactly I can get rid of or plug up on this thing that might help me get it to idle, or should I just go ahead and rebuild the carb?
Any help or suggestions would be great!
Thanx guys... MM
Old Sep 3, 2010 | 10:48 AM
myyota's Avatar
Do you have the fuel cut solenoid hooked up, if not the engine won`t idle.
Old Sep 3, 2010 | 10:58 AM
xxxtreme22r's Avatar
^^^ without looking at your reply first, that's the first thing that came to my mind, especially if the previous owner had a weber on there without that solonoid.
dumpster84
Apr 30, 2016 06:03 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
