v-8 4Runner opinion
Old Sep 7, 2010 | 06:05 PM
rebelrunner's Avatar
v-8 4Runner opinion
What do y'all think about a 2nd gen 4runner with a 400hp 383 stroker, backed by a turbo 400 with a np205 behind it and some leave sprung dana 60's under it?
Old Sep 7, 2010 | 06:14 PM
TOYOTA 1's Avatar
its a good setup if done properly!
those are all good parts.
Old Sep 7, 2010 | 06:26 PM
skoti89's Avatar
yeah man just do the proper upgrades right. That's a lot of freaking power and I don't think a lot of stock parts on the yota are meant to handle that
Old Sep 7, 2010 | 06:28 PM
That's what I'm sayin. I've been thinkin about doin this for a long time and think it would be awesome. But it's also alot of money. I'm thinking about saving up for a long time and then doin it all at once cause the stock yota axles won't hold up to 400 horses.
Old Sep 7, 2010 | 06:33 PM
BajaRunner's Avatar
Heh, yeah that sounds great... whats the reason not many people do it? Money?
Old Sep 7, 2010 | 06:49 PM
Very true. And even though the frame is fully boxed I don't know if it could hold up to it. It'd be alot nicer to drive then with the 150 horse boat anchor that's in there now.
Old Sep 7, 2010 | 06:52 PM
yotaman85's Avatar
that sounds fine and dandy now.. but when its all said and done..... it will be..
Old Sep 7, 2010 | 07:13 PM
flatblackpolaris's Avatar
There are a lot of Toyota's running around with lots of swaps, but it's popularity or lack there of might have something to do with powering a Toyota with American muscle, personally I would consider it sacrilage on my vehicle, but I'm weird.
This is by no means a flame on anyones rig or plans, if you need or want the power get it any way you want...
Old Sep 7, 2010 | 08:29 PM
scuba's Avatar
Want it one hand.. ˟˟˟˟ in the other.. see which one fills up faster
Old Sep 7, 2010 | 08:42 PM
camo31_10.50's Avatar
Scub is right lmao.
why not back away from the power a little....like say a Stock 350...or even a bored and cammed 350..lol
better to be around 250-350hp than over 400
Old Sep 8, 2010 | 03:19 PM
TOYOTA 1's Avatar
did you just say less hp is better ?? your getting soft camo
Old Sep 8, 2010 | 06:29 PM
4x4runr's Avatar
what kind of wheeling do you plan on doing? Tire size? 400 hp sounds like fun!
If it's just occasional wheeling with tires less than 40"s I think it's too much money for something that will never meet it's potential. But if you're going with 44"+ tires and wheel often it would be a great upgrade. I have friends here with stock zuk motors and 38" tires (fully tricked out rigs not motor upgrades) and stock 22re motors that go everywhere....
Old Sep 8, 2010 | 07:49 PM
MudHippy's Avatar
Talking
Why mess around with a domestic V8, when you can fit a Toyota V10 that makes 552 HP and weighs in around the same as a V6 in the same space?
The Toyota LR engine is a V10 piston engine built by Toyota.
1LR-GUE
The Lexus LF-A V10 engine. Announced in the Lexus LFA sports car, the 1LR-GUE is a 4,805 cc (293 cu in) DOHC engine. The engine is made from aluminium alloy, magnesium alloy and titanium alloy and is smaller than most V8's.
The oil and water pumps are located at the rear of the engine and the lubrication system uses a dry sump. Titanium is used for the valves and the rockers arms have a diamond like coating. Each cylinder has an independent, electronically controlled throttle body.
Keeping with traditional practice for high-performance Toyota engines, Yamaha was contracted to co-develop the 1LR-GUE.
Maximum power output is 412 kW (560 PS) at 8,700 rpm. Maximum torque is 480 N·m (354 ft·lb) at 6,800 rpm. The engine will rev to 9500 rpm, with 90% of its peak torque available from 3,700 rpm to 9,000 rpm.
Bore x Stroke (mm): 88.0 x 79.0 Compression ratio: 12.0:1 Vee angle: 72 degrees
http://en.wikipedia.org/wiki/Toyota_LR_engine
That's what I'm saving my money for!
YEAH RIGHT!!! I WISH!!!!
BTW, the Lexus LFA by itself costs $350,000 USD. And I don't think they'll let you purchase just the engine for it on it's own. Not in the forseeable future that is.
http://www.lexus-lfa.com
Looks like it'll bolt right up to a R-series Toyota tranny though huh?
tobylab
Jan 18, 2016 07:06 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
A2theK
Jul 12, 2015 10:46 AM
Yotoder865
Jul 9, 2015 07:51 PM
