Overheated axle shaft?
Old Sep 6, 2010 | 05:37 PM
the_supernerd's Avatar
I am replacing the wheel bearings on an '86 4x2 axle. After getting one of the shafts out and inspecting it, I noticed a small ring of blue color between the dust seal and the wheel mounting flange. It seems too far away from the wheel bearing to be cause by that. What would cause that? Could the truck it came out of been overloaded enough to stress the axleshaft? I am mainly wondering if it is safe to re-use or if I should get another shaft.
Old Sep 6, 2010 | 05:50 PM
Here are some pictures of it.
Old Sep 6, 2010 | 06:44 PM
Exiledbikr's Avatar
Clean all the grease off of it and see if it is still there, i might just be from the type of grease that was used, and is there any grooves of any kind? if not id say it should be fine
Old Sep 6, 2010 | 06:53 PM
rebelrunner's Avatar
It'll be fine.
Old Sep 6, 2010 | 07:08 PM
BrianJE's Avatar
I agree Its fine. Use it.
Old Sep 6, 2010 | 07:29 PM
trfytoy's Avatar
Could be from the process of making the axles. Not from the wheel bearings so run it.
Old Sep 6, 2010 | 10:18 PM
iamsuperbleeder's Avatar
you tempered it; it's stronger now
okay not really, lol, I dunno...
should be fine, I wouldn't worry at all about it
Old Sep 7, 2010 | 05:02 AM
RustBucket's Avatar
Looks like heat treatment. I rebuilt a CV last week and it had sections that were blued like that to make certain surfaces harder and wear resistant.
Old Sep 7, 2010 | 05:48 AM
It does kind of look like heat treatment. Thanks for all of the input. It sounds like it should be ok.
88sasturbotoy
Jan 30, 2026 01:57 PM
A2theK
Jan 10, 2016 10:18 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
ripp96
Jul 25, 2015 02:32 PM
