Why is my rebuilt 3.0 overheating?
Old 08-31-2010, 12:48 PM
ToyoTom's Avatar
Unhappy Why is my rebuilt 3.0 overheating?
I recently had a rebuilt 3.0 V6 (3vze) put in my 95 4Runner. It ran fine for over 1500 miles and is now overheating on simple 10 mile commute home. Oil was changed at about 500 miles and fluids are checked regularly. Any ideas why it has started overheating?
Old 08-31-2010, 01:01 PM
Greg_Canada's Avatar
Bad thermostat? Air in teh system? Does it overheat then cool down, overheat then cool down? (you would need to burp the system)
Old 08-31-2010, 01:11 PM
ToyoTom's Avatar
It overheats when sitting still, if I am moving the needle goes right back down. How do you 'burp' the system?
Old 08-31-2010, 01:32 PM
xxxtreme22r's Avatar
don't know how it goes on the 3.0 but on mine with the 22r place the front of the vehicle up on ramps remove the rad cap and run the motor with the heater on until the thermostat opens. run it for a bit and then add more coolant. run it again till the level does not go down. If you can it helps to squeeze the lower rad hose while the engine is running to help the air out.
You might have a bad thermostat as well.
SubiKing
08-21-2021 03:57 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Logz808
07-26-2015 07:09 AM
Jeffreynmandy
07-18-2015 08:26 AM
Quick Reply: Why is my rebuilt 3.0 overheating?
