PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Injector connectors on wiring harness
  2. 22re: lost my idle adjustment screw! help!
  3. Another ISR mod thread
  4. 1994 4runner 4x4 actuator???
  5. Electric Fan Help!
  6. Roof Rack help
  7. Windshield install
  8. 3.0 Propane Injection
  9. Need ignition install help!
  10. 87 4Runner IFS squealing / bearing/spindle Q's
  11. my idle is low after i drive
  12. 93 4wd 4runner with steering issues
  13. Long travel vs SAS vs Stock?
  14. Front Drive Shaft Vibration
  15. 1990 Front end repair
  16. T-case Q for the Aussie/Kiwi crowd...
  17. Header Question
  18. 3vze startup hesitation
  19. "Hey Corey, where is my thread?"
  20. '88 pickup 22re cold start noise (paranoid?)
  21. suspension question
  22. 1993 4x4 rear end
  23. I need help! im redoing front suspension parts
  24. Oil Pump or bearings 1991 Toyota 3vze MOTOR
  25. 95 toyota pickup electrical problem
  26. alternator output...
  27. 90 pickup slipping into 4wd
  28. Running with MAF sensor?
  29. Won't start, starter tests fine.
  30. adding seafoam to intake
  31. Throttle Return Spring
  32. Dash Cap
  33. Head gasket? White smoke at start
  34. Plug in front of Intake Runners?
  35. Rough Starting When Warm
  36. Help with welding a v6 3rd
  37. 87 automatic 4unner transmission problem
  38. Dying interior parts.
  39. eLocker availibility
  40. Where can I get brake shims?
  41. Newbie with knock sensor wire question
  42. just had alignment and still shakes in the steering
  43. 4runner Soft Top ID
  44. Turn on the Map light, turn off the clock???
  45. the ticking dashboard
  46. Trim Question
  47. a/c bracket ground wire
  48. Load sensing proportioning valve
  49. 86 22re toyota pick up hard start in cold weather
  50. fuel tank skid bolt size?
  51. knock sensor wire part number
  52. Spindle or CV has a lot of play in it...
  53. GNTX-140 rearview mirror
  54. Headlight problem!
  55. Power seats in 90 pickup?
  56. 95 4runner 3.0 is missing on 3 cylinders?
  57. Water in the tail gate/dumb jeep drivers
  58. Lean Question?
  59. 2nd Gen 4runner steering packages...anyone buy these?
  60. 4Runner Roof Leaks!
  61. 2nd gen 4runner stock flex
  62. Prerunner Style!
  63. Installed OEM GPS/Bluetooth radio - PICS
  64. 87 runner wont idle
  65. knock sensor questions
  66. Electrical Gremlin - '88 4Runner (V6, auto)
  67. Tranny over-reving
  68. 89 4runner doors
  69. cam + oversized valves
  70. IFS Flex picture!!!!!
  71. What is a good price for a set of used 3.0 headers / crossover tube?
  72. 93 Clutch Problem, 4wd Truck, Help Needed
  73. I just bought a 3 spoke steering wheel from a 91 for my 88...
  74. Detroit Full Locker for IFS 7.5"?
  75. over sized valves and cam question
  76. Gauge cluster compatible?
  77. 1987 4runner interesting engine miss
  78. Fuel Pump
  79. Do I have a ADD diff? Which diff fluid do i use?
  80. Need some help with 3.0 Gauge Senders for Oil & Water
  81. 89 pick up wont start
  82. 4wd not working, light is on, lever is engaged but still in 2 wheel drive.
  83. Exhaust problems!
  84. Are G52 and w56 transmission shift levers interchangeable
  85. Birffield Eliminator kit Q
  86. 22re bad tensioner??
  87. '92 has no power
  88. Compression Problems
  89. 93 4runner, Hard to start at first and boggy, what is my problem??? Help!
  90. 2nd gen to 1st gen 4runner swap
  91. Rough idle, miss firing as engine warms up ??
  92. Official "86-95 Pickup IFS lift thread" READ FIRST
  93. ISR fitting question
  94. LC engineering questions
  95. fender flares?
  96. Fan always kicks in when starting. Any way to stop it?
  97. 19902Dr4Runner-rear suspension
  98. zuk mod, installation and thoughts...
  99. rough idle when lights are on
  100. Bumpstops?
  101. ford frame swap
  102. radiator question
  103. 4runner rear axle whine
  104. Truck won't start.. VAFM?
  105. idle adjustment screw?
  106. 4runner stalls!
  107. Coolant leak
  108. Mileage Question
  109. TPS Adjustment?
  110. 22r performance rebuild suggestions.
  111. Please Help me with a SAS 1st Gen
  112. My power window switch got me thinkin'...
  113. 22re NEED HELP smoking like crazy!!!
  114. Clutch Issues
  115. Gas door broke
  116. Dash gauges work but lights dont come on
  117. IFS Bracket Lift with Long Travel
  118. 88 4Runner Help !
  119. 3.0 Cam Bearing
  120. Transmission swap
  121. Jeep to 95 4runner...need some tips
  122. standard transmission leak
  123. 4Runner Seat Swap
  124. Tire wear issue..Please help
  125. need someone to measure/look that has an auto
  126. Can someone verify this vacuum line diagram for an 88 22re?
  127. 22R Rocker Arm Alignment
  128. idleing on 94 pickup
  129. 1993 Pickup Suspension lift options
  130. 95 4runner hesitation between 1,500 and 2k
  131. Oil leak issues
  132. Late model intake swap - 22re
  133. Oil Pan Gasket?
  134. Bad IAC/AVV problem specific symptoms
  135. PCV valve mod
  136. where to find running board corner?
  137. Easy Electrical - Fuse Keeps going
  138. Intermittant No Start...
  139. 93' Pick up Electrical Problems
  140. Rear Shocks
  141. Custom Bumper
  142. rough idling, cel on off, tapping
  143. Are these ebay gears any good
  144. Idling Rough?
  145. Daddy got a new toy
  146. Check Engine Light.
  147. replacing a cv joint?
  148. Vacuum lines,all in a kit ?
  149. Sliding Rear Window?
  150. 88 Pickup 92 engine
  151. Winch mounting question
  152. Truck wan't start
  153. Cat back dual, or single pipe?
  154. Group 31 battery in a 4runner V6 Possible?
  155. IFS front diff with Aussie
  156. drivetrain grinding
  157. 3vze TPS check
  158. 22re ThrottleBody mods
  159. white smoke, coolant loss
  160. 22RE Rebuild by 22RE Performance?
  161. Timing chain cover: how bad does it have to be..
  162. Got my Bud on
  163. GL-4 vs GL-5
  164. swapping 3.0's
  165. Sigh... I'm back. Strange Noises and Starting when cold.
  166. Adjusted Valves..need advice..PICS
  167. 3vze engine knock
  168. Cam position sensor?
  169. 1991 4runner SR5 JDM transmission swap
  170. Leaking front DIFF PLEASE see pics HELP!!!
  171. Crankshaft bolt size
  172. Just Bought a Gen 2
  173. 86 4runner door panel swap??
  174. Power Steering Air Valve Bad
  175. 94 runner needs rear brakes?
  176. Yakima Racks
  177. Binding 4x4
  178. Hard to start 22re when in the cold
  179. 3VZE won't idle after cleaning TB coolant passage
  180. front end grinding noise
  181. 94 4x4 vibrates under engine decel in 2nd and in 4th around 40
  182. How many transmission bolts?
  183. 22re running with miss
  184. weight of 6ft bed (89-95)?
  185. starting problems help
  186. Recent running problems with 22r. Need Help
  187. Valve Tap?
  188. Rims corroded to spindle. Possible options for removal?
  189. 2nd test drive and runs high
  190. Loosing Oil??
  191. Starter problems / electrical problem
  192. 89 22RE Won't Turnover
  193. truck now throwing code 52:help
  194. What size bolt for my skid plate?
  195. How to remove rust from INSIDE box frame?
  196. hissing sound/overheating 94 22re pickup
  197. 94 4runner diff. actuator
  198. xtra cab doors
  199. CEL code 4: Need advice on replacing water temp sensor and loosing EGR nut
  200. cursed with code 52!
  201. HELP...4x4 Not Engageing...1991 4Runner..??
  202. parts swap 89 v6 to 86 4cyl
  203. swap from mechanical to electronic speedo?
  204. Tranny seals?
  205. 3VZE high-frequency jingling from left cylinder head area
  206. Door LOcks dont work!:(
  207. front lockright locker part #
  208. 2.4 & 3.0 Wiring harness
  209. 95 4runner v6 fuel leak, help
  210. 89 runner idle problem
  211. Hi from North Dakota!
  212. spark test 3vze
  213. 86 pick up speedo issues
  214. HELP! 22re timing chain noise....just replaced it!!!
  215. oil filter relocation on the v 6
  216. Introduction and 4x4 issue
  217. Nobody sells a rear sliding window panel?
  218. 3VZ Rebuild
  219. Re-Sealing Water Outlet.
  220. My build (reassembly) thread
  221. Flipped my 2nd Gen into the ditch...Advice?
  222. Coolant Overflow
  223. Thank YOU !!!
  224. body lift frame coverage.
  225. loud tapping and knocking
  226. 1987 gas flap cable routing
  227. 1995 4runner wiring problem
  228. Seafoam
  229. #3 cyl low compression ?
  230. 22re wont start its trying but just wont? help
  231. Front wheel bearings, dial torque wrench ok?
  232. Common coolant leak areas.
  233. Passenger side floor wet?
  234. transfercase question?
  235. 86 4runner problems.
  236. Cold air on Passenger floor
  237. Help, overheating problem still unsolved
  238. CEL CODE 24 and 31
  239. Engine Computer
  240. Check Engine Light Question
  241. 3VZE oil pan gasket: cork, FIPG or both?
  242. Please help me identify this wire
  243. Grille Swap
  244. 22R lost compression cyl #3...?
  245. noise from under passanger side. grinding
  246. Need help identifying VSV vacuum switching valve on my fender well
  247. In for t-stat, out with head gaskets, h2o pump, timing belt
  248. Timing guide not broken!!!
  249. Gas puddle under garage floor
  250. If you have an 89-95 ex-cab auto trans......
