4runner rear axle whine
Old Jan 20, 2010 | 05:00 PM
2yota4wds's Avatar
Hey this is my first post on here so bear with me. I have a '90 4runner that I just got running after an engine rebuild. It's a 3.0 with an auto. It has a worrable whine coming from the rear end. I've topped off the fluid and I'm pretty sure it's a bearing but I thought I would post to see if anyone knew which bearing might be the culprit. It starts whinning pretty quick around 15mph maybe even a little sooner then that. I only whines when I'm on the gas, no noise at all when you let off. Thanks for any info you might have to share.
Old Jan 20, 2010 | 05:09 PM
InternetRoadkill's Avatar
They usually whine when you let off the gas when it's a bearing. I'm wondering if you have a bad ring and/or pinion gear that's got a problem on the drive face.
Old Jan 20, 2010 | 05:12 PM
2yota4wds's Avatar
I'll check it out unfortunatley I probably won't get to work on it until next weekend I just wanted to get some ideas before I got started thanks
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
