1987 gas flap cable routing
Old Jan 15, 2010 | 04:26 PM
67ghiaTIV's Avatar
Silly question but....
Can someone please show a pick of how the gas flap cable enters through to the interior. My key lock is missing the key, so I am trying to add the cable but I don't see how it is routed. I assume it just sits under the carpet once inside.
If you have a pic can you email it to jamielamb545@yahoo.ca
Thanks
Old Jan 15, 2010 | 04:32 PM
Bigblock's Avatar
I'd have to go look.Never gave it any thought.I assume you have a 4Runner.
Bigblock
Old Jan 15, 2010 | 04:42 PM
67ghiaTIV's Avatar
Yes it is an 1987 4runner. Trying to get an interior put in it.
Thanks,
Old Jan 15, 2010 | 04:47 PM
Bigblock's Avatar
I have a 90 model and the best I can tell it's under the carpet all the way to the rear where it disappears into the wall on the pass. side rear and goes to the latch.
Bigblock
PS I didn't take my interior out to get you that info.Mostly just guessing.
Old Jan 15, 2010 | 06:38 PM
weaselman's Avatar
on my 86. it comes from the pull lever. along the driver side then behind the driver seat but close to the rear seats and then into the rear pass side panel where the filler neck is...
i only kno this becuz i cut mine out it was in the way. lol.
(its also buried under a couple inches of tar)
i can try to get pictures of where it used to go..
Old Jan 15, 2010 | 06:57 PM
abecedarian's Avatar
Missing the key lock? If the flap is missing the key lock, what's keeping the flap closed?
On mine, the key goes through the flap and turns a cam that is attached to the lock.
so no lock... no cam... flap is permanently open
Old Jan 15, 2010 | 07:57 PM
67ghiaTIV's Avatar
currently just flapping in the wind. The key is missing so the lock is not installed.
Last edited by 67ghiaTIV; Jan 16, 2010 at 01:49 PM. Reason: changed "is" from "in"
Old Jan 16, 2010 | 01:45 PM
85TurboRunner's Avatar
Along with the cable you'll need a different lock assembly. The ones that came on trucks with a gas door cable are different then the normal ones.
coreyedwards7611
Jan 16, 2016 06:38 PM
altydog
Jul 28, 2015 10:20 AM
CanRunner
Jul 20, 2015 01:29 PM
shar
Jul 9, 2015 12:38 PM
Nickdigg
Jul 7, 2015 06:04 AM
