Recent running problems with 22r. Need Help
Old Jan 17, 2010 | 12:01 PM
dubs740's Avatar
Well here's the problem buds. 2 days ago my truck had a hard problem starting in the cold. well i sprayed some starter fluid in the carb like i do on real cold days and for some reason it finally started but only on 3 cylinders. well after about 30secs it switched over to 4 cylinders and sounded good again. so i drove it for 2 days straight and finally yesterday i'm driving home and i start losing power in certain gears. first it was 4th, then i would only drive in 3rd, then 2nd and right before i pulled into the driveway it backfired. It felt like it was hesitating and jerky and losing power in those gears. So now its sitting in the driveway and I dont know what the problem is. Any ideas? Could using the starter fluid alot on cold days be a factor? I'm lost.
thanks,
Paul
Old Jan 17, 2010 | 12:06 PM
myyota's Avatar
Check the simple things first, start with the fuel filter, when was the last time it was changed ?.
Old Jan 17, 2010 | 12:09 PM
camo31_10.50's Avatar
yea fuel filter dude..LOL
maybe fuel pump?
clogged line?
check the fuel level in the sight glass as well
Old Jan 18, 2010 | 11:00 AM
dubs740's Avatar
fuel filter is good.
Old Jan 18, 2010 | 11:02 AM
ibeamtaco's Avatar
ck 4 vacume leaks
Jun 1, 2021 01:51 PM
gillesdetrail
Nov 19, 2019 12:56 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
