- soon new paint
- bumper question
- Why dont I have this part? and should I ?
- 3.4 swap donor in NH
- Tippy is going Moab Camo! (Paint that is)
- New mod
- timing belt trouble
- No Spark, strange prob
- speaker install
- headlight not illuminating
- GOT MY RECALL DONE (Steering Relay Rod)
- Vibration on the interstate
- How low can you go?
- New flywheel or resurface?
- 7mge -vs- 3.4
- Zuk Mod vs Rear Flex!!!
- Just getting slower
- 94' 4runner Bumper for Sale
- rear window
- clutch problems
- 22re Throttle stuck?
- Shackle question
- 1995 4 runner....... problems.....
- ISR Mod-Any problem??
- Expansion Valve
- Bucket seat mounts.
- New brakes= Mushy pedel and strong pull to the right. Please help!
- leaky 22re please help
- New paint on the runner
- Very Rough Idle / Basically No Runability
- Anybody else have trouble getting the 1st generation windows down?
- 4 Sale 4Runner 4 Sale
- Alt Upgrade - GM? MR2? Aftermarket?
- 87 22r 5 speed need more power
- No Crank Like Battery dead
- Rough Running and Rough Idle
- Aftermarket sunroof experience?
- Transmission Problem
- High pitch squealing/whining after intake install
- How involved does replacing intake manifold gasket get
- 95 4Runner A/C Proplem
- looking for camden apex strips
- shackles for a 2wd???
- Muffler Issues
- Regear question....(from 4.3 to 4.88)
- first 4runner air bags
- i used the zuk spring mod
- Manuel locking hubs vs. stock.
- new exhaust no o2 hole?
- putting my window in, glue?
- installing a atv winch on your toyota
- Cup holders
- Drive Shaft Issues
- Water-Proofin A 22re. Whats Involved?
- Tail gate Beeper
- '94 4Runner 3.slow spewing coolant
- Replaced HG, now I'm skipping with no power
- Trouble code 25 - Please help
- removing cargo panels - 4runner question
- Why isn't a shim required?
- Coilover or all 4 corner leaf conversion...
- Locked up 22re!!
- remote turbo install link
- Brake Diagnostic's, please
- Need Help...my project is being held up!
- extended cab SASed pickup
- BJ Spacers, Cruiser Coils, OME shocks,
- Installing OME dakar rear leaf springs
- Bumper options???
- Value Questions
- 4Runner 95' 4Sale in VA, Fairfax. 1500$ OBO
- Rode trails today topless...
- ISR Mod hose location
- 2nd Gen Toyota 4runner praise.
- Rea end help ASAP PLEASE!!!
- 22RE Distributor for Sale....
- A/T Neutral without startup
- Oil in my Galley?
- What is going on with my engine???
- IFS steering troubleshooting question
- 31" - 32" - or 33" with 4.88 gears. What you think?
- Got nothing but time, paint, and parts
- causes for the annoying code 25 & 26
- What is this called and how is it supposed to work....
- Cyl 4 Misfire Idle Only
- Brakes work in neutral/park but not in drive
- V6 cab harness to 22re chassis harness???
- To cat or no cat... that is the question?
- got new exhaust! question!!!
- 4cyl vs V6 3rd members...differences?
- 3vze heads
- Please help identify shift boot & bezel
- Rearching vs New springs...
- Need a heavy duty timing chain for '88 22RE
- SUPRA motor swap
- need some help
- 2" spacer cause axle to shift?
- New Engine....almost
- 3.0 versus 22re
- anybody on here from near sarasota fl?
- Paint for mc bumper
- Timing chain replacement recommendations in L.A.?
- Timing chain broke, right?
- Auto Tranny
- Knockin in the engine
- 88 Toyota Truck 4X4 Fuel Problem.
- 92 4runner weird electrical problem...
- Who has gone wiht the 3" Tg springs?
- Knocking?
- Acceleration Problem
- Power Steering VSV questions.
- Need pics of A/C on 3.0
- Engine hesitation and Over drive trouble
- Anybody running Cragar soft 8 wheels??
- 3.0 Gasping
- Gauge Adaptors
- To buy or not to buy?
- AW4 conversion
- Yalls 1G's Ever Hard to Shift Outta 4wd?
- Revving
- Please help Yotatech, messed up big time changing the brakes
- Firewall Grommet
- Timing Chain?
- High Compression 22re
- re-assembling 22re, what do you do first, head or timing chain cover?
- Think this cam would pass smog?
- Stupid misktake - Pulled apart engine for HG repair - where do these wires go?
- Idle drops at stop lights
- Need parts List for 5 Speed trans.
- transmissions
- Opinions on 3vze HG Job/Parts list
- Spark Plug wire guides
- Low profile bumpstops andbj spacers?
- ISR MOD sucks...
- Good Price for a 4.88 LSD Third.
- idle help
- My RECALL Date is set......
- Will bed from '89 Xtra Cab fit '88 Xtra Cab?
- Who's got the best deal on wheels and tires?
- Egr
- Recommendation for rebuilt 3VZE short block source?
- Mileage On Original Timing Set?
- ECU Tuning
- Bolt cause of oil leak?
- Timing belt replacement and other stuff while I'm in there
- Speed hand
- 88 shock replacement
- Got a new "toy" today...
- Looking into a better front and rear bumper
- 3.slow transfercase help
- 22R Propane Conversion?
- U-joint trouble
- New lights- pictures!
- OME lift on the way
- Gas Gauge Acting up
- Malfunctioning AFM
- what is this worth
- Why do 4Runner windows fog up so much?
- Diagnose my head, oil from seals, or oil from rings?
- cam work from engnbldr
- Alternator Belt
- Vibration
- did hg now 3.0 wont start help!!!!!
- Gearing confusion
- How do i get my water pump off?
- EB 268 Cam: rougher idle?
- New torsion bar problem
- Build-up
- One Sad 4runner
- pickup to 4runner 3rds
- replaceing valve stem seals without removing head, looking for a writeup.
- A few timing chain replacememtn questions, with pictures
- so my rear axel has moved?
- Help / pointers diagnosing temperature gauge problem?
- engine cuts out every 1/1/2 months
- transmission in out, what else to fix??
- 1st gen shackle and spring bushings...options
- New Member that needs some help putting together 4Runner
- idle surges up and down
- starting problems & idle
- Sunroof Crack
- v6 vs 4cyl 3rd
- question about gear pattern pinion depth
- help me figure out this vin for gear ratio
- 33x10.5 with 5.71 Gears?
- 22re turbo bellhousing?
- BJ spacers and lift kit review
- A/C amplifier location/pics?
- Missing During Deceleration
- Oversized fender flares???
- First Gen need ideas...
- add a leaf which one??
- Not good... 3.0 is on its way out
- 33x12.5's w/ 5" BS?
- Fuse diagram question, most likely a stupid one
- Got my custom sliders put on - pictures!
- best mud mod
- 1991 PU gearbox oil?
- 3.0 Head Gasket Issue Explained
- Have you guys seen this?
- 93 Toyota truck won't start after long term storage
- just put on ball joint spacers need to check on shocks
- 2wd pu lift, help?
- leveling out the runner
- Toyota Truck & Landcruiser Owner's Bible
- Out Of Control Idle
- Back spacing
- Starter Problems
- 4wd and 2wd speedo cable
- Runs hot... then rumbles...
- Want to go to 33s.. What and how much?
- 1991 Pickup Shock Options
- Flanges
- adding resonator to a 2nd gen K&N/ISR intake
- Engine R&R book time
- 22re power surges
- 3.0 water pump recommendations
- Need pic of Ranch Stabilzer installed
- 88 runner wont go
- 92 4runner sunroof glass
- sorry probably a repeat question!
- Air shock listing for 86 4 Runner?
- wheel bearings rear...how to change?
- air/fuel mix problem
- 22re to a 2.7
- install coil spacers???
- ~4" Lift In Back = Nasty Noise In Drive Line
- 94 4Runner & newer wheel swap options
- Black smoke
- Bent tow hook issue
- Need Torsion bar Help!
- Need to Tighten up front suspension w/ ARB bumper and Warn m8000?
- Cut out the crossover on the 3.0?
- A/C Compressor turned Air Compressor
- 22R Head Gasket replacement/upgrades.
- Valve Covers Leaking
- Speedometer cable install
- odometer not working. Cable is ok. Any suggestions?
- relay under dash?
- How to Decomission A/C?
- No power to cab
- Guys I really need help!!! Should I or should I not???
- Need pic of rear window assembly
- pre roadtrip checklist
- 3rd Gen Taco wheels fit 87 4Runner?
- 2nd Generation 4Runner Rear ABS dash light
- need help....engine revs up and down both at idle and when given gas
- New radiator advice needed!
- The starter again!
- Tire Question Regarding Size
