Alternator Belt
Old Apr 24, 2007 | 12:48 PM
duburban's Avatar
Alternator Belt
Hey all, Alternator belt broke and i'm wondering how to put a new one on. 94 4cyl 5 speed. What angles do i access, where do i start... and so on. Thanks! Just starting to get my hands dirty with cars.
Old Apr 24, 2007 | 01:12 PM
rdlsz24's Avatar
Check this out: http://personal.utulsa.edu/~nathan-b.../3generato.pdf
It's not too hard of a job more of a pain. You just need to loosen up the two bolts on the alternator so you can make it pivot to get the new belt on. Make sure to put some pressure on the new belt (I use a crowbar against the alternator) or it will squeal like a stuck hog.
Rob
Old Apr 27, 2007 | 06:29 AM
duburban's Avatar
Thanks, will i have to drain power steering fluid to replace the belt? Alternator isn't coming off i'm assuming no.
Old Apr 27, 2007 | 06:32 AM
rdlsz24's Avatar
Nope you won't have to drain or unattach anything. Just loosen up the alternator. Even if you were taking the alternator completely off, you don't have to do anything with the power steering pump. You would have to remove the lower radiator hose to get the alt out, though.
Rob
Old Apr 27, 2007 | 06:38 AM
duburban's Avatar
Thanks Rob, i'll got at it in the rain later!
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
