Runs hot... then rumbles...
Old Apr 21, 2007 | 08:09 PM
thegreydog's Avatar
Rumbling... Timing issues
I have been having trouble with the truck rattling and rumbling sometimes once it warms up. Over the last couple of days, I have begun to notice a pattern. I believe it is when I run the heat. What happens is, it warms up to about mid way, then it begins to rumble very badly when clutch and gas is not engaged. I have been battling this since I got it, I have now replaced the thermo, radiator, hoses, and clutch fan. Someone please help, I am tired of dumping all of this money into getting it to run right, when I should be out wheeling...
Thanks
Old Apr 22, 2007 | 09:40 AM
thegreydog's Avatar
Ok it seems nothing to do with the heat. I went out and cranked it up and it is still doing it. I jumped the diagnostic box, and it idled down. So that means the TPS is working correct? Just needs adjusting? Why would it run good for days or hours and then go to crap? When I put the light on it, the timing was jumping all over the place. I did get it set, but the idle continues to be rough...
Old Apr 22, 2007 | 10:03 AM
thook's Avatar
Have you tried troubleshooting by the FSM?
TPS sounds like it's adjusted fine.
Is it misfiring at all?
Old Apr 22, 2007 | 01:50 PM
thegreydog's Avatar
I have now gone through all of the obvious. It just sucks that it is not a constant issue, so every time I get to someone that could offer suggestions, it straightens out. So I remain lost....
Old Apr 22, 2007 | 06:05 PM
thegreydog's Avatar
What changes from idle to when the gas is pressed. When it is running idle (almost cutting off) a simple touch of the gas and all is well. What changes between idle and throttle? is there a sensor or valve that changes?
Old Apr 22, 2007 | 06:26 PM
thook's Avatar
So, you're saying it's not missing?
Yeah, there is a temp. sensor that could causing this. Let me ask you first, though. Have you tried driving it? Does it die a lot when you get to a stop? Do you lack a lot of power?
Old Apr 22, 2007 | 08:58 PM
thegreydog's Avatar
This is all at random, I have not been able to make it happen. When it does it, it is extremely rough at idle like someone is twisting the distributor 5 to 0. Like put your truck in 3rd or 4th and let off the clutch. The shaking and stalling feeling, touch the gas and it goes away. No lack of power at all, when the gas is pressed, it is like nothing is wrong.
Thanks for your response
Old Apr 22, 2007 | 09:09 PM
thook's Avatar
Well, it does sound like something is trying to give out. But, don't buy any more new parts, yet.
I don't suppose the CEL is throwing a code, is it? Have you checked it?
Disconnect the TPS, drive it, then see if that makes any difference. If not, start looking at your coolant/water temperature sensor and/or fuel pressure regulator. How old is your fuel pump?
Do you have the FSM downloaded?
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Apr 22, 2007 | 09:38 PM
thegreydog's Avatar
I was getting a 5 and 6, after cleaning the TB and checking the TPS, I am now getting 5 and 7....
Old Apr 22, 2007 | 09:47 PM
thook's Avatar
Have you seen this? Here's the codes.
http://www.off-road.com/toyota/tech/codes/index.html
Take a look at your ECU and the wiring. See if there's any corrosion. You have multiple issues going on. I'm wondering if the ECU is fritzing on you.
Do you have a digital multimeter?
Old Apr 23, 2007 | 10:39 PM
thegreydog's Avatar
Yes, I have a good Fluke meter.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
